Intermittent code 26
check your timing, and check at the base of the harness side of the o2 connector, my shielded wire was broken right up against the connector, I am fixing it now..
Timing is good And luckily the harnesses are all fine. I checked them 2 times actually. It ended up being the O2 sensors giving me the troubles.
Thanks
:(Damn,
So previously I used some older O2 sensors to limp me along until I got around to spending the cash on some denso sensors. Well they worked for a while before throwing the cel. I installed some denso's on Saturday and all was just fine until yestwrday am. Cel just popped back on. And then turned off. And it did it again this morning. From what I've gathered it only happens when it's cold and then once it hits 160* or so it turns off.
93/94 sensors aren't typically Denso, but NTK. Toyota P/N 84965-60110 for the set, around $200 online.
Not definitively claiming that this is your problem but others have suggested that the 93/94 are sensitive to sensors for some reason.
I also had an o2-sensor related code intermittently for a week or two when Mario was starting up, mostly while we were on the Blue Ridge Trail. New above O2s took care of it, FWIW.
I've always ran ntk sensors on my rig but they typical only last about 1.5-2 years.
I know a few guys with 93-94 that run the denso's with no issue for several years.:meh:
I had heard that O2 sensors were more of a 100k mile type item, not a 1.5-2 year item. Might be more serious issues afoot if they really crap out that often?
id think that miles would play more of a factor, But its always been about that time period.
this is the NTK part number I used in the past. NTK 24044 {#24070}
i'm currently running the DENSO 2344520.
since its turning off within a minute or two you think it could be the ECT?
Time to start chasing wires unless your engine is runniig like s***. IIRC, your engine has around 325k. It seemed
to be runniig well up at gold lake though. Have you replaced
The cats?
I did the head gasket about month ago and now getting the intermittent code 26. FSM suggests one of following could be trouble area.
Engine Ground bolt loose
Open E1 Circuit
Injector Circuit
Injector
Fuel line pressure
ECT sensor
Compression pressure
ECM
That's long list of things to go thru. I checked all the engine grounds. They checked out. Like @93yotasr5 I have replaced lot of parts as part head gasket job. New plugs, new rotor, new rotor cap, new wires, new spark plugs, new injector sockets, sensor oxygen sensors, new exhaust, etc...
My guess is injector(s).
My intermittent Code 25 26 has gone away, what is strange is it happened at the same time as I switched from RotellaT6 to Chevron 400LE.
I always thought that the ZDDP in the Rotella T6 is what was fouling the O2's. I have cleaned the O2's and Cats with good luck but the intermittent 25 26 came back.
What I found was that if I did all city driving, I would get code 25 26. With all highway driving the CE light stayed off till I drove all city miles again. I have done a ton of city driving with the Delo and still no CE.
I did drive the through Canada with the 80 to AK, not sure if that cured the problem or????
The cats?
Open E1 Circuit
Injector Circuit
Injector
Fuel line pressure
ECT sensor
ECM
So I am right around 325k and it runs great. In the am when at the first stop light of my drive I hear the engine idle a bit rough, cel turns on and then after a few miles of driving it turns off. I've checked all my wiring harnesses, haven't checked compression or my fuel pressure. Wondering if they are getting tired.
I ordered another ect sensor to test out since it was cheap. We'll see what happens next.
Now I'm getting code25 and 26.
Changed out another VAFM to see if that would make any difference. No luck. Checked all of my engine grounds and they are all good. does anyone know how to test the fuel pressure? im gonna rule out the O2 sensors as well since they have 30 miles on them and are Denso.
replaced my ECT last night and now my truck seems to idle differently.
Did it fix the issue?
Nope:(
I tested my open/close circuit relay per the FSM instructions and it seems to be faulty. I have a new one on the way. It doesn't seem very common to have those fail. Anyone hear of them ever failing?
I may have same issue. I will test two of terminals with battery. But couldn't finish the test as I did not have alligator clips on hand to power the relay to finish the test. Good luck with fix. Did you order the new relay? It seems expense for relay.
I may have same issue. I will test two of terminals without battery. But couldn't finish the test as I did not have alligator clips on hand to power the relay to finish the test. Good luck with fix. Did you order the new relay? It seems expense for relay.
I didn't eh two tests without the battery applied and it failed the first buy passed the second. I'm assuming that's enough to fail it automatically. I found a used one on eBay for 8$ shipped. Saw some new ones for 15-20.
If the used works then I'll buy a brand new one and keep the used as a spare.
Keep me posted on your progress as well
Well,I see why my CE light doesn't come on any more...the bulb is burned out...I will have to open the dash and steel the seatbelt light bulb and use it for the CE lamp. Here I thought my 80 was going into its second childhood and fixing its own problems but it's just getting older... like it's owner.
Nope:(
What is this relay's function? Where is it located?
PURPOSE
The circuit opening relay provides power to the fuel pump relay.
OPERATION
One coil is energized when the key is turned to the start position. The relay contacts close and power is supplied to the fuel pump for starting. Once the engine control module begins to receive a signal from volume airflow sensor it grounds the other coil which continues to hold the contacts closed after the key is released to the run position.
