Intermittent code 26
Middle Tennessee
hey all,
I've been chasing down this code for a few months now and cannot figure it out this time. It's an intermittent code 26. Usually comes on when I am stopped at a light. When it happens I hear the idle slightly stumble for a quick second and then the cel comes on. Then a couple minutes after driving it turns off... Usually.
This last weekend I removed the throttle body and cleaned out all the vacuum lines, IAC port , I've replaced all of my vacuum lines, fuel filter, cleaned the Vafm, checked the intake tube for cracks, replaced the o2 sensors, new plugs, wires distributor cap and rotor are all newer. Can't think I of what else might be causing this issue trust me I've searched a ton on code 26. In the past it was always just the o2 sensors. But now I'm stumped.
Molon Labe brother! Glad to know you have you priorities straight. The only time I had code 26 was when my HG let loose and it hasn't returned since the repair.
I'm wondering if your wire harness has not been compromised somewhere. When I did my HG I found my harness to be well worn so installed a brand new. One area in particular that showed considerable aging and wear was the section of wire leading up and over the trans to the inboard O2 sensor.
Have you inspected your harness in the area of the egr valve?
Hmm I haven't checked the wire harness anywhere yet.
I will check around the o2 harness connectors. I have cleaned the connectors to both o2 sensor plugs, IAC plug and tps plug and added dielectric grease to them as well.
Check your ect sensor up above your oil filter to the right of it,
check it in what way? Connection? or with an OHM meter? if so what range should I be looking for?
thanks
thanks
You need to remove it and heat water on your kitchen stove using a thermometer so you know the temp. The FSM shows this test and a graph displaying the correct resistance through the sensor at a given water temp.
I don't have a FSM and the online version I use I cannot find anything about the temp sensor
How many miles, does it use oil, what brand oil used?
Do you do mostly city, or hwy miles?
Find all the ground straps on motor, unhook them, clean the mounting surfaces and hook them back up.
What brand of O2, wires and plugs did you use?
Do you use cheap gas or Top Tier Top Tier Gasoline
Almost 320k
Doesn't burn oil
Rotella 5-40 and Napa gold or Toyota filter
NGk plugs, wires and o2 sensors.
I use all tiers of gas in this thing
From what I have read here, only use OEM O2's. Many have had problems with aftermarket O2's.
Rotella T6 is good oil but the added ZDDP (zinc) coats the catalytic converter and O2 sensors.
My motor uses oil, I use T6 oil and have intermittent code 26. I removed the cat and O2 and cleaned them in a solution and passed emissions test after failing. I still have the intermittent code 26 but only if I drive city miles for a tank or two of gas. After driving all hwy miles the light turns off and stays off till I drive city miles again.
The bad ground theory runs right along with the fact that it's intermittent and rather random and infrequent. Either that or danmage to the harness somewhere. Have fun with that. ;)
ive always used the NTK o2 sensors without any issues. the sensors are only about 2 months old.
I did check the plug terminals for corrosion already. One thing I haven't checked yet is the harness itself or some of the ground straps.
as far as the ECT sensor goes on the engine block does anyone have the specs?
thanks
So I did the old propane vacuum leak test and didn't find any leaks, the grounds straps all look great. Now I'm getting the intermittent code 25/26
Lean and rich? Sounds like the ECU is recieving erroneous signals. When it comes to sensors I will opt for OEM only as long as they are available. Thiose O2's might be worth looking into. The comment landtoy80 made about running DEO with the extra ZDDP has me wondering. On the other hand many on here run DEO as well.
Yeah I'm wondering about the o2 sensors myself. They are the same ones I have always used though. That's why it has me thinking it's not the o2 sensors. And since they are not more than 2-3 months old.
Id hate to go drop 300 bucks for new Denso sensors only to have it not remedy the problem.
If your motor uses no oil, the added ZDDP wont build up very fast, but as the ZDDP can "flash out", you don't need to be using oil to foul the O2's. As it uses more oil, more ZDDP coats your O2's.
What is strange with my 80 is, I use a lot of oil. 800 mi last qt. but I don't get the intermittent code 25 and or 26 if I drive all hwy miles. It must be the constant flow of heat that cleans off the build up on the O2's. With city driving, the slower revs of the motor and more idle time fouls out the O2's. Not sure if using Shell gas 95% of the time helps clean the O2's or if just driving all hwy does the trick.
Oil Additives & Supplements - Diagnostic News
ZDP/ZDDP is actually a family of compounds with similar properties. But, they are not all equal. They vary greatly in their ability to remain active in the crankcase oil during normal operation. Some of these compounds have high volatility and will “flash out” quickly leaving the crankcase oil through the PCV system. This shortens the life of the oxygen sensors and catalytic convertors. The loss of ZDP/ZDDP can also compromise critical engine protection whenever operating conditions require boundary layer lubrication.
http://www.aa1car.com/library/zddp.htm
- What happens if you use a ZDDP additive in a newer vehicles that has O2 sensors and a catalytic converter? If you follow the recommended dose on the product and don't overdo it, and if the engine is not using an unusual amount of oil (less than a pint between normal oil changes), it's doubtful the ZDDP will have any negative effects on the oxygen sensors or catalyst.
However, if you continue to use such a product long term (many tens of thousands of miles), it may eventually cause some contamination and shorten the service life of the O2 sensors and catalyst. The O2 sensors would be come sluggish and slow to respond to changes in the air/fuel mixture, causing a drop in fuel economy. The catalyst might lose efficiency at converting exhaust pollutants into CO2 and water vapor, causing an increase in tailpipe emissions. Either of these conditions could be a problem if you live in an area that requires emissions testing and your Check Engine light comes on, indicating an emissions fault. Your vehicle will not pass an emissions test if there are any issues with the O2 sensors or catalyst.
Do High Performance Engines really need extra zinc?
Can too much zinc harm your vehicle? Even in well performing engines, tiny amounts of oil may end up in the combustion chamber or volatilize as the engine runs. The same antiwear additives that protect the engine may turn into ash if the oil is burned. As the ash is blown down the exhaust pipe, it can stick to the oxygen sensors and settle in the catalytic converter, rendering them less effective over time. This is definitely NOT a catastrophic failure event. However, engine manufacturers need to reduce this effect because they warranty vehicle parts for tens of thousands of miles and several years.
Just tested the vafm. I am not getting the correct range between VS-E2. The range should be 200-400ohm and I am getting 190ohm. I am going to see if anyone has one available for me to test and see if that is the culprit.
Thanks
Thanks
I was just about to point you in this direction. Those codes indicate that the injector timing that is originally calculated (base timing) is producing a value that requires the ECU to compensate with either more or less timing that is beyond expected limits.
