Rocky_LC said:No Comment about the rust, but....
Is this "outboard" spring hangar setup perhaps due to some other mods the guy has going, like running 60 series axles? Here's some discussion on this topic..
https://forum.ih8mud.com/showpost.php?p=791669&postcount=5
If you look under the other side, the U-Bolt retaining plate is one of those fancy SOR skid plates - maybe this guy made some mods for technical or performance reasons...
OBTW: It's missing a driveshaft.....
Rocky
Mace said:Rust aint scary.. The tear marks and crack in the frame is creepy..
'd up on the rig. I vote for "run away".
Archengine said:I'm more worried about the lack of retaining bolts in the shackle bolt than the rust. Really long u-bolts probably from the local hardware store. No driveshaft?? No washers on the bolts holding the spring bracket to the frame. Whats up with the rusty plate welded behind the 'boxed' frame section. Seems to me the PO never took his time to do the "modifications" correctly, and tried to get done as fast as possible. I would not feel confident or safe driving this truck. I would assume from this picture that the rest of the truck is done this way. I would not consider it.
mooker82 said:The 40 Im looking at has some interesting frame mods. Has anyone ever seen someone do this before? Why? Should I run?
