- Thread starter
- #61
The display on mine cleared up and is showing all the time now. Not sure why.
I was considering this head unit for my 100 series. Given your issues, but now unexplained recovery, would you still recommend it?
Found that out after the fact too. I even emailed the rollover guy because I didn't know why it wouldn't work. I use inclinometer by gelosav on Google play, it works rather well without the accelerometer.Just a heads up. There isn't an accelerometer in this unit, or any other head units, so it's not compatible with inclinometers like RollMeOver. But, you can probably mirror your phone and run the app on it and display to the Joying.
I've been noticing that the usb port does not seem to be able to keep up with charging my phone while running maps and music at the same time. It will just hold the battery percentage steady but it does not increase. I think I'll just charge off of a powered port unless I need the phone connected directly for something.
Nope. I think you could use a weather app if you tethered to your phone or mirrored to your phone.Is the unit able to display outside temperature? Is there a port in the back for a thermometer plug?
https://www.amazon.com/gp/product/B01ET3Z2Q0/?tag=ihco-20
I've had this 7" headunit since May and I really like it. The customer service with this particular seller is great too. I have contacted him four or five times with questions and always received an answer within a day.
