sleepycruiser
I will get by….I will survive
- Thread starter
- #381
I had thought about it....I might check some out at Northern Tool if I get any spare time.
Why a thermarest?First camping trip in the RTT this weekend and I have to say I really couldn’t be happier with it. After a couple trial runs setting it up and “learning” it setup was a breeze and after the pointers about the interior bungees take down was MUCH easier and quicker. I slept fine in it although I will probably use a Thermarest on top of the mattress next time. The boys loved it. My wife and I and both boys and we had plenty of room in it and it felt really stable. Totally happy with it and ready to use it again.
Why a thermarest?
Looks rad! What's the height to the bottom of the tent to the ground? Also - your truck has ome heavies, correct?
So the part of the ladder that actually attaches to the bottom of the RTT you are leaving on, but sliding the bottom portion off?
I wonder if that will help me get into the garage. I can’t get into the garage either.
Out of the box it was a couple of inches short. I had to re-drill the holes for the ladder pins a few inches lower. It works fine but I'm sure it stresses the ladder a little more with a smaller connection point between the two sections. I noticed that you have the ladder extension which is the best way to do it. My way does work but it's not ideal.@roadstr6 are you able to get by with the length of the ladder or is it a little short?
Once you go through setting it up a few more times you’ll knock off at least another 10 minutes off setup and takedown times.
The tension rods have to come out to fold it up. Helpful hint: Install the rods from inside the tent. Unzip Windows and screens. Lean out. Insert rods into base at 45 degree angle. Grab flap. Bend rod and insert into flap. I did these rods from the outside once and it’s a pain.Going to try to get mine on the roof today. So the poles all have to be taken down before putting it back up?
Amazon Prime day....I am going to try to find some good solar LED lights.
Good to hear. What brand is the changing room? Any pictures?I used this tent during the weekend and it pass every test
Comfort test. Approved, kids and I slept like babies.
Dry test. Approved, two nights of hard rain and we were dry after all
Set up test. Approved, no as bad as i thought it could be.
The changing room “ even when it is not the exact one for my tent” made it easy to change the kids without making a mess inside the tent.
Over all it is a 8. Not a 10 because i will not take it to Logans run since i dont want to take it down to go wheeling.
Thanks again
