1991 4Runner SR5 V6
Was told that head gasket was blown, holds 18 pounds for over an hour. Nice little fuel leak at the rear of intake area that appears to be a valve of sorts. Has a solid miss, so I pulled the plugs, air cleaner and cap and about s***!
Replaced it all tonight, runs waaaaaaaaaaaaaay better but not as it should. Does this fuel leak drop that much pressure to not fire the injectors correctly?
Also truck has sat for the last 6 months.
It will be getting timing belt, belts, WP, T-stat, Cam seals, front main, valve cover gaskets, intake gaskets as most are leaking at a good rate.......................
Any solid tips other that pulling the intake to replace that unit on the back of the fuel rail.
Best,
Shane
Best,
Shane
