Or just advance it a couple of degrees and see if it gets better under load?
I am not convinced that my mechanical advance is working correctly. I finally found the notes in the FSM about the order of advance for the mechanical advance. I'll check that after I eliminate the muffler.
Do you have details on the spring kit? Or was that for a different distributor?
Sounds like your tank vent is plugged. Leave your gas cap off give it a try. Could be the problem.Shaft bearing appears fine. Cannot close the points. I checked the gap while I was in and it's 0.018".
The coil is hot to the touch, but I can hold my hand on it.
I checked the brakes, front, rear, and parking. All wheels turn by hand. The driveshaft turns easily with the parking brake disengaged.
Oh, and I filled it up at the gas station. Opening the gas cap and it sounded like I opened a soda can. Can't tell which way the pressure was going.
Tomorrow is muffler day.
It's a new gas tank, hoses and gas cap. I assume you mean the separator (or something in that circuit)? The one-way valve is working. (At least it was when I redid the fuel lines.) The valve should allow pressure to pass out from the fuel separator, right? (Another thing to check isn't ass backwards.)Sounds like your tank vent is plugged. Leave your gas cap off give it a try. Could be the problem.
Well make a race tractor out of that thing yet.I am sure hoping it’s just a fuel thing…!
Simple stuff, is the choke-butterfly opening fully? Is the throttle and cable or linkage working like it should? There is a fuel-inlet filter on the carb that could be restricted. This is one of the more desirable alternative carb options, in my opinion.It's the Rochester Single Barrel "B" or "BC" carb as far as I can tell.
The choke is opening fully. Throttle cable works correctly (now).Simple stuff, is the choke-butterfly opening fully? Is the throttle and cable or linkage working like it should? There is a fuel-inlet filter on the carb that could be restricted. This is one of the more desirable alternative carb options, in my opinion.
Stock mechanical fuel pump? Not clogged fuel filter?
I wouldn't say "paralysis", I am actively looking at all possibilities and ruling out items that could be issues. This truck sat for a LONG time before I bought it. There are systems, like the exhaust, that I haven't gotten into.A suggestion. Not sure if you can swing it.
1. Confirm your fuel pump is delivering fuel at idle and when you rev engine. Disconnect fuel line to carb and use a paint cup to measure quantity of fuel for 5 seconds of flow at idle and at 3000 rpm. Latter should be a higher.
2. If above checks out, find someone with a good working carb and switch it in. Try to see if speed improves. If it does, its your carb.
3. If it is not your carb, find someone who us willing to switch out their good working dizzy to yours and see if speed issue resolves.
4. If above fails, its in your driveline somewhere.
Not the easiest route, but process of elimination will get you off analysis paralysis.
Every carb I've worked on has a screen at the fuel inlet. Typically, they come with rebuild kits, however, they usually only need cleaning. Something like part number 14 - Rochester B, BC, BV Diagrams and Exploded Views - https://www.carburetor-parts.com/diagrams-exploded-views-rochester-bThe choke is opening fully. Throttle cable works correctly (now).
I'll check the condition of the filter. I assume you mean the one pictured in this post: I can't drive 55 - https://forum.ih8mud.com/threads/i-cant-drive-55.1347969/post-15664287 I don't think this is a serviceable part, but I'll see what I can see.
Yes, stock fuel pump.
Fuel filter looks good, but I can replace that easily enough.
Here's the photo. #4 is a vacuum line that goes to the oil filler tube.She's probably pregnant... seriously lets see a photo from the other side of the carb where 2 originates
