Build I bought a Whale, now I gotta build it and use it
@RustyNailJustin took me for a morning trip through the Cimarrons to his family cabin then back to Montrose for a great burger.
This adventure is complete. Leg 4 of the great western adventure trip Compared to the great distances we traveled the last 3 legs, 615 miles does not seem like much but it was a lot of great riding in the San Juan range
5250 miles since we hit the trails on the TX/NM line 7 months ago
This trip was special because Red came with me. We spent yesteday afternoon and today enjoying Ouray hiking and eating. Even got a massage and some hot springs action
200 drivers.....I have a question about all these gee whiz gadgets and how to make the truck do what I want.
Here is a video of me going to the same spot the 80 went up and failing.
Weight is the main factor here. I'm sure my truck weighs 1500# more than that Saudi 80.
What was happening here. I was in 4low. I tried different traction settings but none of them would let me truly "bump it" like you often need to do.
I would floor it and the traction s*** would come on and it felt like all the HP was gone.
I think I toggled it from Loose Rock setting to Rock then I tried without the traction control completely. Give me some tips. I was very happy with all of the 200 gizmos except in this one spot.
I did it in a similar line with a rear locker, but over to the left starting and still putting that crevice in the middle of my hood and went right up, but that was last year and it was dry so slightly different conditions
Traction was on rock, but I don't rely on that . I use the power braking technique to get started
Looks like a good place to use the CRAWL feature, to me.
HTH
I knew I could get up the bottom of the right side but I also knew the break over angle was going to kill me. I went for it knowing I'd get stuck but I really was not expecting to get as stuck as I was
As I understand it, you can turn off all the babysitting tech by holding the traction control button for 3 seconds.
What was your tire pressure?
16-20 is depending on the temperature
Trust me that's not it. This thing is heavy as hell
It really crawls well. I did not slip a tire anywhere in the 5800 miles leading up to this. It's just a bit too steep right there but a good bump would have gotten me up.
This is why Mud is so great. Thank you. A single push did not do the job
Glad to help! Especially after all the tracks and trail reports you share that I’ve benefited from. One of these days our paths will cross because you’ve either just done stuff we’re about to do or just wrapped up something we just did.
@wngrog If you hold the the Trac Off button for 8-10 seconds you should hear a beep. That will remove any traction controls and allow you to "bump it." I don't have a 16+ and this is what works. Hitting the button quickly will turn the light on, holding it will yield a beep and then your good to go.
Sweet. Sometimes one needs some "Mo"
This morning we woke up with a heavy frost and shared the lake with some Mule deer.
After breakfast we beat feet to Green River for gas then hit the dirt for the Maze District.
This is the most remote ranger station in the lower 48. 59 miles off road to get there
