HFS 5" reports?
Any out there?
WHo's running what size tire with the HFS 5"?
Did you turn the knuckles or just use the shims?
I have the impression CCOT offers a 4" and 5" spring set. both are supposed to be used with 2.5" shackles for proper 2 stage articulation/flex/whatever.
I don't want to do a SOA simply because in order to do a SOA correctly traction bars/control arms should be added to prevent axle wrap/whatever you call it on the front and back which boils down to complicating or adding more metal, whereas maintaining a SUA only requires the cut/n/turn. Then for highway purposes sway bars might be required as well. Of course this depends on who you talk to. May as well use coils.
Basically, I prefer the springs under the axles with a U bolt flip kit. In my mind maintaining a SUA simplifies the lift and it's function has been well proven.
I've got 5+" with the 4" springs and extended shackles. I used 4* shims and am running 35" MTRs. Tested this weekend at Round Up. Worked perfectly. You might get away for less $$ going SOA, but only if you know how to do it yourself.
LukeO said:
, whereas maintaining a SUA only requires the cut/n/turn..
I am guessing this a typo. because with spring under you do not need to cu-n-turn, you will need caster shims, but those should come with waht ever lift kit you use
You are right. When I picked up my springs, Gaylon at CCOT showed me the 5" springs compared to the 4". They are different. You won't need to cut and turn with these. Any more lift than that and I think you would.
fjmayo do you have any more pics? how did they flex. i am looking for what to do because i want good flex and have been looking at the hfs, any info would be great
