I started to watch, but fell asleep during the intermission.
Remind me to bring snacks next time I watch...
Haha!
When you get back to the great state of Iowa, we are racing! This will be the start of a new thread.
Haha!
I'm not sure I'll be an 80 series owner when I come back; I just stumbled into a mother lode of diesel, not completely rusted out BJ 40s....
I happened to be in there this morning - this is what I found.There is? I've never seen one and there is no mention in the parts catalog.
That is what I was referring to, I thought it also was set off if the truck is inverted.I happened to be in there this morning - this is what I found.View attachment 1196413
It was mentioned earlier, but I'd do a slightly different check based on your continual chase for spark.
When you say you are getting no spark, are you allay using part of the engine block for a ground? Have you tried using the battery negative? The comment mentioned earlier wa to check your grounds, the reason I bring it up again, is I have had a ground strap from the block to the frame come off. Without a ground to the block, you won't get spark even if everything is working properly. It's the other half of the fuseable links.
