There are small puddles of oil all along the top of the head, and every surface (rockers, valve springs, rocker shaft, etc.) is coated with some oil. Definitely not dry. And that's after sitting another 14 or 15 weeks since I was last out here. There's a decent pool of oil sitting in the rear of the head (low spot due to slope of garage floor) that's drained from the rocker assembly, etc. over that time. Given what I posted just above, it doesn't look like I have any stuck lifters (unless I'm missing something).Even if you get all the pushrods under control, without oil to the head, you're on very borrowed time. If you really have stuck lifters, is there any sense in adjusting the valves? If you do it anyway, and start the engine, you should see significant oil flow to the head within 60 seconds of starting.
Only got up to 104 this afternoon, about 45 miles NW of Las Vegas (still in Clark County, Nevada).shoot, I thought AZ was spossed to be hotter than cali...
I know lifter #7 pushed the pushrod up in contact with the rocker arm sufficient to compress the valve spring. That's the position it was in at the time I had cylinder #6 @ TDC on the compression stroke.Seems like you may have had a siezed lifter. Does the lifter in said hole #7 cycle as it should?
Didn't get hot enough for me here at our place outside Las Vegas, so we're headed into town where it's 111 right now, down from a high of 112.shoot, I thought AZ was spossed to be hotter than cali...
