H55F 5th gear issues
New York
I have finally registered the 40 today and took it for a spin and when shifting to 5th gear, it's no engaging at all and feeling like neutral. Now I did remove the top cover plate, at one point of the built, to change the gasket, and assuming something did not go right in.
Any ideas, before removing the transmission?
Daniel
Pull the top off and make sure all the sliders line up to neutral position when you re-assemble. I bet the one for fifth gear is out of place and you gear lever isn't engaging the shift fork. Shouldn't have to drop the tranny for this fix.
I hope is just that!. But I don't understand how the 5th can move at ease without the fork being in place. And yes, won't remove the tranny, but is a PITA when foing this on a later tub and having the tranny close to the cowl, I'll figure dropping the Xmember and hold it with a jack so it's on an angle and inspect.
Thx!
Had a similar problem with my 55f gearbox had a rumbling noise which when away with clutch ingaged I was told the noise would be the input bearing I replaced the bearing and when apart I also found a lot of movement in the cluster shaft front bearing so I replaced that put everything back together all seemed well and I drove the car from my workshop to my home next morning on the way to work once I hit the highway tried to engage 5th and just popped out I tried it once more and just wouldn't engage so I tried to engage 5th later at work with the engine of and slowly let the clutch out but it just popped out after pulling the box apart and deciding to do a full rebuild I discovered it was not fully engaging 5th and found the 5th gear fork had been hot and bent it was working fine never had a problem getting 5th gear before or never popped out of gear no load grinding but once the bearings had been changed it the fork was so bent from the worn bearings and heat it would only just start to engage not meshing properly and pop out every time
Well that's my theory that because there was so much slop in the front cluster it was forcing the fork upwards creating it to get hot and bend which worked fine and suited the old bearings until we took all the movement away anyone else had this happen does it sound legit ?
Might also consider posting or searching the 60-series forum. More H55 swaps over there. I've heard a lot about seats and rails and forks falling out of alignment when the cover is removed. I hope that's your answer, sounds promising.
The 5th gear and shift lever is external from the rest of the transmission. You should be able to see if the external portion is connected properly just by pulling the trans hump. If it is connected properly, pull the trans top cover and try to turn the 5th gear shift pivot at the top of the extension housing by hand to feel if the fork is properly engaged with the shift collar.
I found even with the external shift disconnected 5th was only just engaging and since stripped the box and transfer bought a full kit and new fork there was 4 mill difference in the new fork I also found the rear cluster or countershaft bearing was chewed out and chewing into the gear behind it due to the amount of play in the front cluster bearing I should have it rebuilt in a few days and see how it turns out
Finally got my five speed this week. Pulled shift cane. The nylon type race the cane rests on is toast and in pieces. The nylon piece if there did not come out with the cane. It does shift in all gears which is a plus. Next before buying any parts to rebuild it is to inspect the inside. Is there a secret getting the shifter loose from the shaft for fifth gear? Don't want bent the cone shaped dust cover to pry it off.
It’ll come right off pretty easily. You can save the boot if you’re careful by pulling it back off the lever, but they’re still available if you tear it.
The plastic shifter bushings are still available for just a few bucks, too.
Are you saying take it apart at the ninety under the boot? I folded back the tabs and removed the bolt from the shaft. Thought the collar would slip up and off the shaft as you lifted top coveroff.
Need to locate a manual if it looks like it's worth rebuilding inside. Have to tear down to replace the input,somight as well rebuilt it. Before I order anything just want to be sure what's inside. Oil was to the fill plug and clear which is a plus. Just haven't heard good things about used H55Fs from Australia.
These pics of any help?
You don’t need to unbolt anything from the 5th gear selector. The rod from the shift cover will come right off of the selector. It’s hard to describe, but if you slide the boot back a little, you’ll see how simple it is under there.
This confused me at first until I realize it was for a 60/70 series so when looking at it I was 180 degrees off because of the location of the opening for the shift cane.
I see 5th shift arm shaft (from the cover) connected to the 5th shift arm connected to the 5th shift arm shaft (from 5th gear extension housing). I removed the bolt to slide the 5th shaft arm up and off 5th shift arm shaft (from the 5th gear extension housing). Are you saying disconnect the the 5th shift arm from the 5th shift arm shaft (from the cover) that is under the boot? It's not clear how it comes apart under the boot and didn't try moving the boot to see. Diagram doesn't show any type of connect like it does for the bolt and lock tab on the extension housing.
I'm not sure if the original manual is still available?.....The pics I posted are from a reproduction manual that's published here in Australia using AMI Toyota material.
I know I would interested in one of these reproductions. The mating transfer case as well. Possible they are sold on eBay AU? Has to be easier to get to the US then the five speed. Do you happen to know if all split transfer cases in Australia have a PTO gear inside? Date code for the transfer case is on top and not by the PTO opening which is weird for a 83 transfer case. Another thread was brought up may have been because it was with a H55F. Wondering if this may be the case for the PTO gear as well.
