H55F 5th gear issues
I just checked three 4 speeds with split cases, all had PTO drives....I have a 5 speed with a split case that's never been apart, I'll check that tomorrow.
No need, it probably has one. Haven't dealt with enough of them here to know. Have a local market one from a 82 mated to a H42 and it doesn't have one. Another one from 90 attached to a A440F and has one. Find it interesting because of the location of the inner CAT a PTO wouldn't fit.
This confused me at first until I realize it was for a 60/70 series so when looking at it I was 180 degrees off because of the location of the opening for the shift cane.
I see 5th shift arm shaft (from the cover) connected to the 5th shift arm connected to the 5th shift arm shaft (from 5th gear extension housing). I removed the bolt to slide the 5th shaft arm up and off 5th shift arm shaft (from the 5th gear extension housing). Are you saying disconnect the the 5th shift arm from the 5th shift arm shaft (from the cover) that is under the boot? It's not clear how it comes apart under the boot and didn't try moving the boot to see. Diagram doesn't show any type of connect like it does for the bolt and lock tab on the extension housing.
Put the bolt back in! It literally just slides right off the arm. It’s just a lever that slides into a notch in the rod. Pull back the boot and you’ll see
I put the bolt back right after I took off. Mainly so wouldn't lose the tab lock or bolt. The shift lever is not going to just slip off the shaft. being exposed though the joint have something that needed apart but not really different than how the arm operates the 4WD shaft.
That first picture shows all I need to see. Removed the bolts and got it off with no problem. Boot was not a issue and didn't get damaged.
While the box is apart replace the 5th gear with one out of a 75 Series. I have been told it is a straight swap however the 5th from the 75 Series is a much stronger gear and you wont have any more dramas with it.
Looked up 75 series and many are the same part number as the one for the 40/60 series. Some as late as 1992. Found one that has different part number but NLA and seems to be superseded by another part number that is available. What model 75 and year range so I can look up part number?
I bought this off eBay AU and only know it was off a BJ42 that was parted out for rust. I do not know the miles/kilometers on or if there were any issues with it like popping out of fifth gear. Was told it was a running vehicle when parted out. Been on the hunt for a 40 series five speed and figured I would take a chance. Worn out/disintegrated nylon pieces at the base of the shift cane seem to be the worse obvious problem which are easily fixed. Changing the input shaft is another matter.
Well that's my theory that because there was so much slop in the front cluster it was forcing the fork upwards creating it to get hot and bend which worked fine and suited the old bearings until we took all the movement away anyone else had this happen does it sound legit ?
Sorry been away due to bad health but thought I’d update this as I found the problem just hope it saves others the amount of sleepless nights I had trying to solve it..the problem was some moron before me had replaced the cluster bearing and there is a sleeve should sit behind the bearing to stop end float .but this previous weekend warrior put the sleeve in front of the bearing allowing the counter shaft to float and chew the rear bearing out which caused the bent 5th gear fork also the problem I had with the shaft getting tight and not turning once the bearing housing was bolted up .hope this saves someone a head ache and some time
