The last pair of ramps I had cracked! Too bad as I actually liked using them for changing the oil on a Mazda 3 hatchback I had at that time, which was super-low to the ground and difficult to get a floorjack under. Luckily all of our current rigs have better jacking points, so it's NBD to lift them up with a 6,000# floorjacks.I’ve had my ramps for 20+ years. I’ll always trust them before stands. Used them all the time with my Duramax (heavy front end). I have stands. I use them a lot. But I prefer ramps when I’m completely under trying to wrestle a 200+ lb trans out. It wasnt really a problem as the cheap jack I bought couldn’t handle the load with the transfer case. The jack lift worked just fine but the frame for the wheels bent (see pic). I really just needed it to raise and lower. The trans was slid out on its side with help from my floor jack. I’ll weld on larger gussets for reinstall. Bellhousing came out just behind the ramp. I may reinstall the bellhousing after I get it under when going back in.
The chocks are on the drivers side
Your trans actually looks quite clean on the inside, although the fluid is a bit brown-ish. Any smoking guns so far?
