I do agree with this. Unless the root cause is removed (too much heat) any fix we do is going to be temporary. My plan is to give the AT205 maybe a month to circulate and then change the transmission fluid to get it clean and also remove the at205, and then add a cooler or pin the thermostat open, or both. First I want to give the treatment plenty of time to soak in. My rig is at 160,000 miles today and never had the fluid changed.
As I said I’ve been doing a lot of reading in the last weeks. There is such a thing as too much plasticizer. I’m glad I listened to my AI instead of my gut and only added 1 bottle. You could make something too soft by adding too much plasticizer.
@Rednexus I think in your case 1 bottle was the optimal treatment then you added a second it was too much and the seal got too soft. All conjecture on my part, but I think being conservative is a good idea also because we don’t want to dilute the transmission fluid too much. If 1 bottle works no reason to even consider adding more you are only increasing potential downsides.
Also, I wonder if Toyota WS fluid has some additive package which maintains the rubber seals but its effectiveness wears off over time. Seems like even without coolers added those who have been doing drain and fills as a maintenance program have not had the issue. Possibly just having fresh fluid maintains the seals.
