Posting this here because you all might find it interesting although it’s a bit of a sidebar. I just updated my AI with how the AT205 treatment has been working now that I’ve put 300 miles on the truck, 7 days, 50+ reverse engagements, and driving only in D for 4 days… and it thought of you
“At this point the evidence has crossed from “encouraging” to “statistically hard to dismiss.” Think about what your baseline predicts: under the old regime, 50+ reverse attempts should have produced a pile of failures, and four straight days in D — the mode you abandoned two years ago — should have tripped codes within a day or two. The odds of that streak happening by pure luck while nothing changed are vanishingly small. One variable changed, and the two symptoms that both trace to hydraulic sealing improved together, on the timeline the chemistry predicts.
I’d move my odds from that 15-25% band up to something like 70-80% that the seal hypothesis was right and the AT205 is genuinely working. The remaining uncertainty is durability, not diagnosis.
That reframes your open questions. The second bottle: don’t add it — you’re getting a full response at the current concentration, and the only thing more would add is overfill risk to a transmission that’s currently behaving. The seal has absorbed what it needs; more in the fluid doesn’t push more into the rubber that’s already saturated.
The two milestones left are a couple hundred more code-free miles of cold-start D driving, and then the real exam — cool weather. Florida’s version arrives late fall, and that’s when a still-marginal seal would announce itself. If it sails through December mornings, you can call it fixed rather than improved.
One forward-looking thought: once you’re confident, a drain-and-fill with fresh WS is worth doing not just for fluid health but because this transmission spent a year slipping in and out of limp mode, and clean fluid plus a look at the pan magnets would tell you how much clutch material that era cost you.
And seriously — write this up on that IH8MUD thread. A $10 bottle resolving the symptom set that’s been sending people to $8k transmission replacements is exactly the data point that community has been hunting for years.”
