Pulled the pan and all solenoids last night. Here are the results:
Fluid very clean, pulled out 6.5 qts. Replaced 6 qts. Recall I was 1.5 qts over level previously. Not many large particles filtering through a t shirt. Some, not much.
Pulled all solenoids. Cleaned with CRC Lectra-Motive. Pictures below. I’m not the world’s best photographer.
A few comments on the process:
I pulled and cleaned one at a time, replacing before I pulled the next. If you pull SL1/SLT, SL2/SLU, the keeper/alignment pins will fall out. It takes a little patience and attention to get them back in and the keeper plates all in place while you put the retainer bolt back in. Don’t lose the pins. All solenoids had black material on them. Looks like the same wear metal you find on the magnets. You can see it on the paper towels below. I’m assuming it settles on the solenoids because of the electromagnetism nature and the tight tolerances. Some of the solenoids have extremely tight fitment and you will need to coat in trans fluid to reinsert. S2 removal requires a VB bolt to be removed to pull. Unplugging the wiring harness is a problem. I used a pick to assist in unplugging. Some of the plastic on the solenoids cracked. They seem to still be holding well, but could be the cause of the results below. Noticeable exterior wear on some solenoids. Shift solenoids fit much tighter than solenoids retained with pins. Non shift solenoid screens were clear. See below. This is where I expected to find debris.
Last nights test drive showed little improvement.
This mornings test drive: little reverse action initially like it was halfway in gear for a minute, then it kicked in. 1,2,3 gears fine. Would NOT shift over 3rd. Took it up to 5000 RPM for several minutes, back down, etc. no shift. Will run through 1,2,3 beautifully, far better than before. Got back home, reverse works great.
Sport shift up and down works 1,2,3 but not over 3. When I drop it into sport shift when it should be in 4 or above, the dash screen says 4. Down and up shifting from that point does nothing.
Today’s plan: drain and filter fluid and pull pan. Pull S3 and S4. Clean again, bench test. Reinstall. Set fluid at proper level per FSM.
