Today’s update: drained pan, 5.5 QTs. Pulled pan. Pulled S3 C and S4 D solenoids. Performed bench test for resistance and action. S3 13-14 ohms. S4 14-15+ ohms, little high.
refill with exactly 5.5 QTs. Leveled truck. Wouldn’t go into reverse off ramps, so had to push off. Brought up trans temp to 115 on low gauge, 118 on high gauge. Opened level drain and out came … almost 3 QTs. I’m very confused on how much fluid is in this damn thing. I should have only pulled out 1 Qt.
Test drive: initially still no reverse. Beautifully shifted 1-6 gears up and down. No hesitation, slip, nothing. Great! Get back home. Drops into reverse after 1 second delay. Park in driveway running to move another Toyota. Drops into reverse after 3 seconds.
So after everything, I’ve improved forward driving shifts. Back to major problems with reverse. Now I’ll go study up on the relationship between SL1, SL2, SLU, SLT to S3/S4. Because I regained 4th gear but lost more reverse capability. It could be a S4 ohm problem. It could be a pressure issue from one of the non shift solenoids.
Fluid was pretty clean, since I just filtered last night. Solenoids clean. I filled the S3 and S4 with cleaning fluid before activating with a 9V battery to clean around the mandrel as much as possible. Magnets were pretty dirty for just yesterday’s test drive. Getting more junk out.
