Grip tape for sliders
Dallas, TX
anyone have a recommendation on grip tape for sliders?
Always used 3M. I have had a huge roll of it forever and have no idea where I got it. hah.
Google may be able to help. Skate shops, Amazon. Agree with @bajaphile re. 3M.
^^^^ What they said.
I tried doing a rattle can "gritty" spray texture and didn't hold up compare the others, and cheaper and easier to replace.
I like 3m. I know you are not using m tech sliders but ours are similar. I bought it for the outside bar on the slider to help get in wet or dry. But I have enough that when it wears out I can replace and keep it looking new. The link price is for 9 rolls so I split it with 2 other guys and is not too bad price wise.
http://www.amazon.com/3M-GM400-Black-Grip-Tape/dp/B00IOQ41ZW?tag=ihco-20
A small can of Rhino Liner is cheap and has better grip in snow or mud. I just put it on the top of the outside rails and it has held up great.
I use expanded metal on the outer tube, and sometimes across the entire top of sliders I build. I found out that if you slide your leg across the tape it rubs on the back of my leg. The expanded metal is also good for scraping mud off your shoes getting in. I have built a few sets for customers with expanded metal across the top, this is generally to make a larger slider a better step and also to prevent kid's legs from going between the bars.
Expanded metal idea pretty cool...
The expanded metal across the top looks nice, and adds great functionality. I'm wondering how to add that to my existing sliders easily. Without having a welder or knowing how to weld, it makes it difficult
where would you attach the grip tape so as not to scratch your skin getting in and out.
As the owner you get used to it quickly, but new passengers get their skin taken off, my dad was cussing the grip tape after he jumped in wearing shorts and lost skin on half his lower leg. lol.
It doesn't remove skin near as well though.
Well, that's a deal breaker then. :)
I put my tape to just top of the tube, if eaten too much out to the outside of the tubes then yes it will take a lot of skin off. But kept at top it really isn't an issue.
my 3m tape is starting to peel off on a corner... after 8 years or so....
Picked this up a couple months ago, haven't had the chance to sand and relaxing the sliders and put it on.
Don't do what I did.. Keep your grip tape on the top portion of your tube. I wrapped sliders on the top and sides of the outer tube and with the first exit took off about 4 inches of skin on the back of my calf... I'm use to it now but I have to remind friends to be careful exiting the truck
