I have seen coolant temps from 189 to 205 and cant seem to drive a correlation to the boiling/venting. Also I cant make heads/tails of fuel trim data but I can save some and see I'd I have any saved from previous trips where I did vent on by bluedriver app.
I think, knowing everything inknow from the repairs I've done, MUD posts and my experience now with ethanol free fuel my theory is that there are a combination of failure points that could cause heating and/or evap system to be overstretched...as a post on this thread with a youtube video link to evap system overview showed, there is a stop valve within tank to prevent gas from getting into evap system. When this happens the pressure has no choice but to release at the secondary point which is the gas cap that has a spring built in to release this pressure when too much. By fixing exhaust system/cat issues and O2 sensors I think SOME of the heat can be controlled but our older rigs seem to build up heat regardless.
As for the ethanol free fuel, I'm not a scientist and dont know how/why but I seem to no longer build up so much pressure that the stop valve in tank to the CC isnt tripping (even with full tank on hot day) and therefore CC is working and no pressure out of gas cap. I say this bc I did run in traffic on a hot day last week where last year i would have been boiling or when i turned car off i would have at least heard/smelled fumes from gas cap. When I turned car off I had no gas cap venting/smell and could hear pressure going to CC to then burn off that stuff at next startup as intended.
Sooo this leads me to think MAYBE the stop valve in tank wears out over time to where it either gunks up or takes hardly any pressure to close up and not allow pressure to CC. Perhaps if I replace this I could test theory and run some ethanol fuel and see if tank can handle the increased pressure i experience with this fuel type.
In the meantime, I'm running ethanol free 87 octane and not having to stress in the back of my mind all day every day during the summer whether I'm going to vent from my tank!! That's my $0.02 as of today but I am always learning here!
I assure your 189 to 205f indicates something not to factory specs. 205F should only be seen in the most demanding, hot OAT and loaded condition. Even then something is not right. 205F and your CAT will be very hot. I'll take a look at your rig, anytime you'd like to stop by. Please wear a mask (covid BS) here, I will also.
We're thinking along the same lines. That damage is cause by the condition over time. That the fuel shut off valve on vapor return line, may be getting stuck. But looking at parts diagrams in PQ. I do not see this shutoff valve after 02-. Those have CC in back and we may need to approach differently. But first all things under hood need to be at spec regardless of year..
I was just driving my 00LX w/350K+ miles (
Emerald) in stop and go gridlock.:
I've never notice fuel smell, before. But on this day I did, at end of 3 hours stop and go driving around and in Denver at 99F OAT. Traffic is worst than ever these days, with people avoid public transportation. So this was worst case driving. I open the gas cap and got ~3 seconds of hiss, then put cap back on. I then heard CC humming. Went back and released cap again, and got 1 second of hiss. So gas must have been boiling somewhat. The system did it's job. This coolant system is spot on, except old fan clutch, which seems okay (aged). BTW; It's my understanding, CC vents to atmosphere when engine off. That fuel vapor is sucked into intake when running.
I did not get temps and FT while driving that day. Bluedriver had given me a bata driver to test, and it failed. Darn!
I do have two things on Emerald, I've been wanting to do. That is have fuel injectors serviced by Chuck (
FIS) and replace the old factory fuel pressure regulator.
Note: I have extensive service history on Emerald. I don't have first 100K mile out of canada Dealerships, but most all for last 250K miles. It is the longer/thickest service history I've seen. Never any mention of fuel issue of this topic, that can I recall. I take another look. But it spent time in many parts of North America, and last few year in Ft Collins foothills at about 6,500 feet. It was a good climb on slow road too, where it lived. All back top and no shade. So it had, hot, long slow drive daily in the summer.
