Agree with the heat shielding. I have an LRA 40 gal tank coming in August and I'm going to refresh the fuel system lines, add shields in various places. I've never had the boiling issue or overheating. But just in case
What I'm interpreting from @2001LC is that we all don't necessarily need heat shields as a corrective measure- rather getting base engine condition in order before modifying/fabricating heat shielding.
VSVs will DEFINITELY indicate working when tested but still stick. The one on the intake should be checked closely. If that one sticks, you get no vacuum on the canister at all. And again, I'll add this - check for exhaust leaks. Even a small leak is putting 500-800 degree exhaust under the truck, and will boil your fuel. It will be worse if you are towing any trailer, as well, since the trailer messes with the cooling flow of airflow under the truck.
Very interesting, good info! please expand on your experience around this and how you uncovered this.
Vapor Pressure Sensor is mounted on top of the fuel tank:regardless of what conversions, or numbers or units you guys get, that # from -4.1 to +2.1 is next to zero pressure. Your lungs can blow just under +4. kPa So it should be easy to just say you're over what it should be.
umm..... where is this vapor pressure sensor and how can I see it. TS reads Kpa? I've never looked. In the canister?
I'm guilty of not having a fuel smell, vapor, issue for a few years now.
I only put a shield up on the drivers side. I use to hear it boil all the time.
Seems simple to me, it gets hot, it boils, you can hear it boil, do what you got to do keep it from getting hot. MOTO
