Front control arm bushings
Broski
I love Wheelin my 80
At the edge of the Pacific ocean
Hay Guys I need some opinions AND I know this Forums has no shortage of them so let go. I had all new OEM Bushing installed after bending a control arm. The bent control arm caused the Slee bushing to walk, enlarged 4 of the holes in the axle brackets & destroyed metal center of the Slee bushing. BUMMER!!!!!!!!!
After much Debate I went back to OEM Bushing a OEM used control arm & Landtank castor plates.
From what I have read on this Forum Landtank is will respected on this Site. And I know he manufacture's the landtank Plates So I think he would know posted up the bushing are 90* out of alignment.
The arm are back in the truck but it still on block well I finish up some other thing. Do I need to pull the arms and have the bushing rotated. I believe I read on here some years were one way and some years were the other
Subscribed to understand the reasoning that the holes should line up on the horizontal plane. The only reason I can see to line up centered bushings is the way they allow movement and "squish" under articulation.
There was a Service Bulletin on this posted by @cruiserdan some time ago. I recall seeing it, but did not bookmark it. Maybe he will respond to advise.
I've seen them both ways yours are like the fsm, I don't think it really matters I have a set of slee arms where they go horizontal that he pressed in oem Yota bushings, and have seen stock arms oem going horizontal also
here's the one: :edit: landcrushr beat me to it
upload_2016-10-9_22-5-0-png.1333854
OK if I was to do it again I go the new way, But there in so I think there going to stay.
Thanks for all the replies
It is more important that the busing orientation matches side-to-side than which version of orientation you chose to run.
How did you bend the control arm in the first place? That must have taken quite a bit of force.
Have seen several bent, doesn't take as much one would think.
Does this happen during a higher speed "hit" to the front end or during excessive articulation at low speed?
I guess the control arm is essentially a large lever and if it is going to bend, it will be at the attachment point to the frame, like in the OPs photo.
My default install is the first way, holes vertical, allows slightly easier flex. Once they are in, would leave them, when pushed in they crush to size. When pushed out, then back in they go in much easier, likely reducing integrity. In real world use, it makes little difference, have seen them randomly installed, with little effect.
It takes a pretty good hit, accident, roll over, etc. Have seen them bent in relatively minor hits, where it wouldn't be expected, but never in "normal" wheeling.
