front bumper?
I'd be in for one also...but getting the rest of the early cruiser to put it on might be a little harder to accomplish :frown:
There were both the lower, and upper bracket drawings, but I'll let Kevin know some parts might be available as samples if needed :)
Brackets are simple. The upper brackets are the same as on the 62 and later FJ40 just shorter. All you need is to cut a later one down. Then if you really want to be correct you need to fill the hole used for a bolt at the end of the frame. The early brackets didn't use this bolt. The bottom one is just a piece of flat metal with three holes drilled. John (Pardion) might add how hard it is, I sent him the pattern years ago.
I need a bumper for my 40- would one of these fit the frame width?? 11/81 build.
Pete
Pete
A little late on a response but the frame width on a FJ25 is the same as a FJ40 and would work.
I do believe the metal thickest is lighter than the later FJ40s. The mounting system is also lighter. By it's design it will buckle easier then a FJ40. But it is the correct bumper for cruisers older than the 1962 model.
I have been emailing with Alexandra at Pacol about having bumpers made. She has said that it would be possible to make a jig.
I don't want to get any hopes up, but i am looking for a count of people interested. Also looking for a sample bumper or a pattern if there are any still around to send to them. Let me know, hopefully this might work.
I have emailed FJ CO, haven't heard back yet. Talked with the Heritage museum, they said that they would help, as long as the bumper doesn't have to leave their property ( very understandable).
@fjco you should repro early door frames too ;) (i already sent a contact us thingy about that )
technically i don't think annie came with one, but if the price isn't outrageous, i'd take one. i can vouch that treeroot would take at least one, but most likely three
