Fresh Pull Stuck
Spokane WA
Any idea why my fresh pull knob feels like it is stuck in the outward position? Do I just need to lube her up?
d9O2ixtUIaVtiqZ-bSBkyIib24VJnxf4i81tUAhO65e0W-X88UkwATbGqDIsS9m1gyuDj6ylYAGym9Zp8guXwfZciIOFjoFEMfi0I1EojmKm6sNfAJiCUUNf1wGH2r40lU4dN8BCdrgPiwF4b2VTId-QTJJvsFSFuabRhjrgE15_2oGWxc89lUUaj_d7Br3HQvCPCuzKfKDkGhrqM8fcPonHbaFrv_vDeEnBdKmV4vTX2A64CHY4ClCX8gDe08_70rLTwfd12viVIbBs5Dxsbv3k9IJ-D83IEH7OEo4ErcmRTLd-qS9_6aSNsdZ-7K61zaz0e5hiUUT3QtmMGMwhCdnexWApsMYM1k3QonxdXwZUpcRdSLjogG2Cch0qt6SEvVb-3x38FK5WCtrQ9sB2YGCP9lCwP87tRWDD5wi_Yd9PSvAeoV-MINQz9EoAvnFSXkEgonMaeSrwMH4BjKazs4T9tPhzUENXg6002lrA-4K_Xy7BqkBfHk5xtEjn5bbE96mh1_jqCTU5RsqgmRteqdJ4GOSM16xVplwXAMffBiejq7tvLZs38aZd7vJsHWzhczA9RnMHBwsMngEVVkrR52KfYSpmveet4AxeYqORdv0wjB8E6LrQjQ=w1234-h926-no
I guess I should have explained a bit further. It is currently not hooked up to the door. I can pull it out further just fine but it appears to just be stuck here when I try to push it in any further. I refinished the painted letter so it looks like it is new! I will try grabbing the wire end with some pliers, lube it up and see if it breaks loose.
Safer to remove the cable and work on it away from that pretty dashboard.
Mine is stuck too which normally doesn't matter cuz you need fresh to keep the windows de-fogged. I think it just needs lube and to get worked back n forth more often.
I know, i know,
That's what she said.
Also the cable prefers to be pulled rather than pushed due to the design. When you push mine it likes to deflect rather than move the flapper.
