Pablo, You have to remember, I'm running a chevy and placed the motor with my own mounts. Your setup will be different, but I think the only mods will be putting the holes in the right spot.
Ah, right! But Tucker is still running 2F, eh?
Sure is a funny looking 2F if it is ...
Yes - the late H42/Splitcase was installed with the stock bellhousing and transmission mounts. I'm removing the bellhousing ear-mounts and going to a late-FJ60 cross member mount under the H55 with the swap. I would not recommend using the stock mounts, I had a lot of driveline movement (which was exasperated by the soft diesel motor mounts designed to dampen vibration). I will have to grind "dog ears" into this bellhousing to mate with the front of the H55Are you running a 55 bell housing on the 55 mounts?
If yes, that would still translate well to other 55 owners running 1/2/3F power looking for a 5th...
Yes - the late H42/Splitcase was installed with the stock bellhousing and transmission mounts. I'm removing the bellhousing ear-mounts and going to a late-FJ60 cross member mount under the H55 with the swap. I would not recommend using the stock mounts, I had a lot of driveline movement (which was exasperated by the soft diesel motor mounts designed to dampen vibration). I will have to grind "dog ears" into this bellhousing to mate with the front of the H55HTH! Tucker
Because I want to route my exhaust up over the cross member and down the frame rail, something the current mount didn't allowQuestion, why not retain the bell housing mounts and run the tranny mount? Sort of a belt-and-suspenders approach?
Because I want to route my exhaust up over the cross member and down the frame rail, something the current mount didn't allowTucker
It's a kick out, kicks the tire over and hopefully around the rock your sliding onTucker, The sliders look really nice. Good addition. Question about the little bump out at the rear door, just for looks or a purpose other than step? Even though I have IPOR sliders welded in, I wouldn't mind having something like your's, just for a step up.
Yup - beefy u-bolts were supplied with the kit, will try to get a pic later -Did you secure with the h bolts (whatever the squared off u bolts that wrap the frame rail are called) or use nutserts in the frame? Looks good!
