Frame off
Super Sick! While we're off the topic -
We used to build garden tractors up for pulling and ended up with one 8' long running a 250cc snowmobile motor. Sure hauled ass around the back yard. Crappy turning radius tho.
Ok back to topic - sweet build up!
[QUOT
Can you reccomend an epoxy to use on a chassis? And how many parts hardener (catylist sp?) are you using? Plus how about your primer preference? If you don't want to give up secrets no worries....[/QUOTE]
Project is looking good boys.
As for epoxy, no secret at all and most have thier own mixing systems. The product we use is sold by Cloverdale paints here in Canada and is real inexpensive stuff.
If you want more information like mixing sheet or product informatin shoot me a PM with your fax.
Santa came early this year. Good thing I went to pick all this stuff up; the UPS man would have killed me!
We got the firewall about finished. After welding in the few needed patches we primed it with etching primer. It is bascially zinc chromate and will really help prevent rust from comming back.
Long day not getting much done. The hardtop sides are a bitch. Lots of welding and derusting involved.
Went by the machine shop. Looks like the motor got the standard redneck rebuild. The block was cleaned and the crank was polished. Correct rod and main bearing were installed but the rods themselves and the bearing caps were horrible dirty. Original oil pump, cam was trashed as were the lifters, head was cut and ground but the rocker shaft is bad and a bunch of the springs had lost strenght.
Looks like about 1/2 of a real rebuild. We will just start from scratch and do it right. Hope to get it back on Friday.
David-
looking great man........and 90 days is amazing..............if i had 90 days to work striaght on my cruiser and had more than 100 bucks at a time to spend on it it still wouldnt have made the progress you have!
We are still moving right along. The tub should be here next week. We just scored some rust free (almost) doors. The roof sides were bad in just a few places so we decided to fix them.
The frame off took the week off. A rash of 60 series invaded the shop and we had to back burner the resto. We got the axles finished, tie rods done and the suspension is ready to install. By next week we should have a rolling chassis.
Keep the pics coming, lookin great!
Well, Eventually get some real progress. Axles are on the truck as are the tie rods. We can roll it and steer it. Whoo Hoo! We have a 2.5" OME Dakar lift with rebuilt everything.
