Frame off
65swb45 said:
Not a harassment David but.............4 days? My buddy Russ and I did a personal best of stripping 3 Fj40s to bare frames in 1 day. With hand tools. And a lot of caffeine!
You haven't met Sam and Dustin. :D
Now if it was summer and I was workin at the shop.......
the hardtop wouldn't even be off yet. :flipoff2:
It is a shame Bailey cant come down and work. He really does not get much done but he is good to ave around. Not bad looking either. His time at band camp really kills his cruiser time.
We got a bit more done.
JohnL said:
Whose blood is it on the driver's side of the top?
Oh yeah, besides the chain hoist, I vote for the PB Blaster as the most useful tool I saw for this job...
I have a fantasy; it is almost sexual in nature:
I will buy a 40' construction dumpster and fill it with PB Blaster. Then, I will add a 100 GPM pump to circulate the PB. I will lift trucks up on the hoist then sit them in the swirling PB bath for a few days prior to working on them. I need to go have some private time now!
Someday people are going to start noticing that the last 3 of your tards have been minors....... :censor: ;)
albeit only one is particularly good looking. :flipoff2:
It is a shame Bailey cant come down and work. He really does get SO MUCH MORE WORK done than anyone I know.
:flipoff2:
David,
$hit, I thought the fantasy was going to have to do with the blood. You sick bastid.
what did you do to get the frame clean and prepared for paint, double d? The one I worked on was a bear to get all the crap off and out of the frame.
Great post. Keep the pic coming.
Now I have to resist the urge to tear down my DD 40 :D
cruiseroutfit said:
Paint before adding the PS?
What PS setup you going to use?
We will do mini truck. I wanted to get a good coat on it then we will touch up as needed but the mini is a bolt or with just a few welds for safety.
10-4, I do the same thing... I would rather grind off the clean paint... ;)
Looks sweet!
Gus said:
Awsome pics, very nice work on the frame, what did you use to coat it, Epoxy primer, Rust Bullet????
The frame was easy. We first hosed it down and used the blue zep cleaner/degreaser on it. next came about a day of blasting. We used a nice little Snap On spot blaster. This gets all the rust, paint, dirt etc.. off. Then, we ground the flat sections of the frame using an 80 grit flap disk. This removes most of the pits and smoothes it out. Next step is the POR rust killer spray stuff. Just kills the rust! Then hard hat rustoleum primer then hard hat gloss black.
Quote: Next step is the POR rust killer spray stuff. Just kills the rust! Then hard hat rustoleum primer then hard hat gloss black.
I thought you had to use a Tiecoat between the POR and any topcoat. You didn't use POR-15? I'm sure there is a different POR product that I don't know about, but POR-15 needs the Tiecoat for a finish coat to stick?
Looks nice,
Ed
Ed, You are right on the tiecoat but we did not use the POR paint on product. It is a POR rust neutralizr then we topcoated with Rustoleum Hard hat. I will get the name later today.
Do you not find the rustoleum to be too soft? Are you using a gun, or spray cans? How do you get enough paint applied If it is spraycan. I hope you do not tell me you are pulling the tips out of the brakeparts cleaner cans, and getting "turbo rustoleum".
