For Sale, Trade, or Free!
tundra wheels
I also have some 18x8 tundra (x 4)wheels nice shape $250. Buy these and the hundy wheels together and I will throw in an extra 16x8 hundy wheel and tire!!!!!!!!:) So for $500 you get 9 wheels and 5 tires :bounce:
I have one short jump seat frame in fair shape. I bought 3 with the intent to make 2 good ones but was able to just make 2 of them go without taking them apart.
This one was the roughest at the hinge, PO when at it with the big arc welder.
A little time with a grinder and MIG and it will be fine. Asking $40 locally before going to the Part For Sale section
Sent from my iPhone using IH8MUD
WTS: rear reflectors for FJ40
Corner Reflector - FJ40 - 9/73-12/78 - Silver Ring - Pair - Aft. Mrkt
as seen as here on this page.
New in box, never used- was going to install but decided against it.
$20. I can bring them to the meeting.
Metal Tech Front Profile Roll Cage
Prefer to sell local. PM me
Metal Tech Profile Roll Cage: Front two A pillars,
two A to B supports, one overhead cross bar. No mounting plates. $150.00
Bestop Tigertop
$250.00. PM me
No tears, rips or holes, no yellow windows, all zippers work. No soft doors. I do have most of the snaps for the tub that go with it. Comes with the frame and bows; however it will need the sleeve that connects the two front center bows together. Frame could use a touch up repaint. This top came with my 40 when I bought it, but I've never installed it.
Fs: brand new never been used ARB CKMA12 compressor. Perfect for air lockers and airing up tires.
$240. Comes with everything you need. Wiring harness, relay, switch, everything.
Sold it
Side Mirror - FREE
Need a side mirror for a 77-84 40 or 45? I have an extra, as I needed to replace one and bought a pair. It's the aftermarket version, so if you have that arm, you're good, if you have an OEM arm, (with the smaller ball), I guess you can glue a washer to the mirror socket, to take up the slack. No charge, I can bring it to an event, or you can swing by...
The CCOT pic:
coolfj40_2206_369721576
TBI adapter for FJ40/60 $100 FJ40 front Bumper $40
TBI Adapter -- GONE
FJ40 Front Bumper (came off my '79). -- GONE
Good news is I have one very nice clean shop!
(I had cruizer stuff piled in one corner and a bunch of scrap metal/wire/misc for metal recycling yards in
the other side of the shop. Kids were all home and pitched helping clean up the shop..... end of the day
was uh where is that pile of stuff?. :)
Tom Walter
roundrocktom at yahoo.com (BB Phone, so easiest way to reach me)
Hey Tom, how ya been?
Busy, way too busy! That is a good thing, however.
My daughter isn't playing softball this summer. Select teams the last five years have meant every weekend is a softball tournaments all over the state, so it will seem off to be home on weekends!
FJ60 hasn't left my yard in 5 years. Lots of work in pulling out Cedar Trees, and getting fluids changed... but maybe 10 miles a year on it! It's officially 25 years old now, so no more worry about no smog pump!
Cleaning up the shop. Need more room to work on the plane (putting the fuselage on rotisserie). Managed to screw up my back, so no leaning over to weld, hence the rotisserie for the plane.
I keep finding more boxes of Cruiser parts. Yes, I'm a hoarder!
Tom
Con-Ferr Roof Rack from an 80
I bought this about two years ago, did some work on it, bought some accessories and then it sat around like most of my projects. It measures out to be 48" x 42" and its the 4" high model. It's one piece not a bolt together. I spent some time prepping it and painting it, so it looks great, except for one of the mounting cross bars that was bent. I worked on it with a hammer and wood blocks and straightened it out.
I bought a shovel and axe mount for it and a hi lift mount as well. However, I only have one set of adapater plates so you would have to source out another set or fab them up. Defender might make them, but I am not sure.
The floor is open, but it does have the cross bars to use as attachment points. I bought some chicken coop flooring to use, but I never cut and installed them. I wanted to keep one of the panels to use as a shower floor when out camping, but I'll throw the other one in. Farm tek sells these cheap.
I do not have mounts, but there are several sources for raingutter styles and ones that work with stock roof rail systems. Defender did make them, but I have not checked in some time.
Rack and accessories: $250 obo
I might sell separately.
Best way to reach me is probably by phone or here: five wan too, 6 three 2, 1406.
Patrick
If I can't sell everything together, I will separate it out. The problem with separating it is that it makes the Hi lift mounts useless because you need the adapter plates to mount it, and there is only one set of those.
I'm going to give it a few days. I posted it here first to give the locals a chance, and I will post it up on portal today. You will have first dibs on the shovel/ax mount if I separate everything out.
