- Thread starter
- #2,481
It’s only Thursday! But don’t worry, I’m working on a long yarn to spin for my brethren about my custom fuel system and every single little special piece related to itFriday nightwhat's up wit yur
Nik, you’ll be the first to know!
It’s completely not OEM.Is that a pressure regulator? Are you running too much psi or something? Because the vortex should regulate it for you.
There’s a return side regulator on the factory truck manifold fuel rails.Where does the Vortec motor regulate the pressure from?
Dayum! That looks finer than a new set of snow tires!Another small item crossed from the list.
I bent up a template line with 3/8” copper tubing. The benders I had on hand are ok for the 3/16” brake line, but crap for 3/8’s, so after some hym-haw I went ahead and bought this Ridgid 3/8” tubing bender. It’s not tip-top of the line, but worked fantastic for what I need.
I stopped the line just in front of the spring hanger for the rear axle. An in-line filter housing should sit pretty well in this area.
Eastwood and cheap parts store benders on the left, Ridgid on the right.
Here’s the results of the cheap benders on the practice tubing.
This is what the Ridgid’s results look like
First leg of the hardline installed.
Somebody’s getting closer….
