I had a post like this a few months ago - The truck starts up fine on cold start, then I go to stop in a store for 10 minutes, then the car doesn't want to start, turns over but doesn't start once the engines hot. Then it starts after about 15-30 minutes. People said it was the EFI relay that will overheat and then the truck will not have a hot start or will intermittently. I purchased a new OEM EFI relay to replace but now its still having the same problem. The strange part is, I got the truck to start, drove it home, and to test if it would start right after shutting it off hot, I shut it off then not even 3 minutes later started it again and it started right up. Then I waited 15 minutes, went to start again, and couldn't start but would turn over. What is going on???
Side note: battery is brand new, fuel injectors have been replaced, efi relay replaced, spark plugs replaced
