post a pic of the line you need. I have a couple line sets not sure which rig they came from. also I forgot to get you those pics of the tank lines, so I'll try to get those posted today.
The only pic of the tank I have with lines on it is this one. Does it pretty much go back like they are laid out in the pic?
Also, this is the ATF coolant line I need. From lower Pass Side, over to Driver Side Radiator (32941A) the hand written number should be Toyota parts #.
Mayday! Mayday!
Just pulled the thermostats housing and found this..... what is it and how screwed am I?
Keep in mind this has sat for 11 years, and to my knowledge it was parked because of a blower tranny cooler hose.
Little update:
In the process of replacing fuel filter, the mounting bracket tension bolt snapped in half. Still have to drill it out to try and reuse the mount...
I've got a video of the motor turning over , but for some reason it won't compress enough from my phone to uploadOk, been out of town for the past few weeks.
I was able to test compression, although numbers look a little off to me. I had put Marvel Mystery Oil in the cylinders a few weeks ago, so I guess this counts as more of a 'WET' test.
1988 FJ62 336,037 miles
#1 172PSI
#2 135 PSI
#3 160 PSI
#4 125 PSI
#5 155 PSI
#6 170 PSI
Aside from number four, numbers don't look terrible. Granted, this is essentially a wet test. Advice is appreciated, but looking at this now, I will probably just do a full tune up, flush the block and install my new radiator.
