I talked to Georg at Valley Hybrids today. Definitely seems like a good dude, and someone I will do business with once I tear into this thing. The plan is to pick her up on Monday. Hopefully this rain holds off a little so I can start in on the fuel system first.
Georg is the best. Hands down. Period.
Dropping the fuel tank is a real pain, before doing that I would drain it and see what comes out, then decide if dropping it is warranted.
Very much so, it's a real knuckle busting job. Seriously. Ive got it down to 30-45 minutes, depending on bolt stubbornness/rust, but I have done it many times. Double it for you.
I would pull it, but before putting it back in, cut out an access hole/panel over the fuel pump so the next time around you can just pull back the carpet. Mr T got smart and started doing this in the 80s on. Very easy to do once measured out and no one will know unless the carpet is pulled. But you have to remove the tank as the clearance is very minimal and you don't want to 1) cause a fire or 2) cut into the tank. Both of those are $$$$ options.
