If you really want to split hairs, LCP... your setup shouldn't pass visual because there's only one cat. Either way though, I like how you've routed it. I was going to do what you did, but after I installed a 1" body lift, I'm seriously eyeballing just running it down the inside of the frame rail.
Dan- since I'm considering running my exhaust on the inside of the frame rail, how hard would it be for you to make me a set of sliders without the cat pan and instead just a straight arm like the other two on that side?
Mandrake,
I don't think that would be an issue at all. We could bring them up an inch on the mounting plates as well to accommodate the 1" body lift/stay closer to the pinch seam on the body.
Not everyone wants to do that on their rig. But I do agree that moving the cat is a great idea. Although having a low hanging cat protection does seem to lessen the need for skid plate a little.
Although I am wondering why the TEQ plate is on the bottom of the tube and not on top where it could be used as step. Also that's a ALOT of steel on the cat protection, with enclosed design mud and debris might get trapped in there.
Qball,
The cat skid has thirteen 2"/1.5" holes as well as a generous gap around the control arm bracket at the bottom. Wouldn't be difficult to revise it to a more open design and I'd gladly send out a replacement for anyone experiencing an issue ... but it will likely always be a compromise between real protection from rocks and being open enough to only collect minimal debris though.
We've run the 'spanner plates' (between the rectangular tube and the round tube) as we call them the other way, but the Arizona rocks here had a tendency to grab/catch the open edge. We have been recently offering bolt on or weld on (aluminum and steel respectively) step plates with the dimple dies running whichever way the customer has preferred as well. This gives a full length step as opposed to shorter steps as well. Running the dimple dies upwards in steel gives the best grip for your foot/shoe of course (not pictured here unfortunately)
http://www.nextventuremotorsports.c...rs/11823823_10206028091034247_380111153_n.jpg
