my answer would be
don't risk it. at 60 PSI you will dump your oil supply in seconds ... literally. ask anyone that has had that BB blow out the side of their 3FE.
make an adapter between the BSPT fitting and the larger oil feed fitting.
if you have the proper taps then it wouldn't be that hard.
if not then almost impossible
... Which of the three wires from the injection pump is the one for the fuel solenoid? I'm guessing two are for a tach sensor and one is for the fuel solenoid. I have the following wires coming from the connector, a yellow/red spots, a black/red/brown spots and a black/brown spots. The fuel solenoid has a green wire before the connnector that has been messed with already so I don't want to beat on it too hard and be screwed with a bad solenoid.
lostmarbles said:Maybe these pics (on testing the fuel solenoid and tach sensor) help with that:
Well two wires had about 800 ohms across them and the other wire was significantly different so I assume that to be the solenoid. We'll know if that is correct when we try starting the truck! I simply connected it to the "M" terminal for the old EDIC motor. I figure that terminal had to provide power for the EDIC motor to run the old engine so it should have continuous power when starting and running.
or just grab any wire that has power while the key is on and you are golden, that solenoid takes very little power.
While I work out the connection for the oil feed for the altenator vacuum pump I'm going to have to use the altenator I got to make the Dyna 12v. It is beleived that this is an altenator from a mini-truck but I have no way to know for sure.
Does anyone know what these various pins are? The terminal designations in my "B" engine manual are "S", "L", "IG" and "B". I'm 99% sure the threaded post is "B" but which of these pins are the other three terminals?
