Ugh! That does suck. I recon they gotta get your $$$ somehow.....Yes, but "test only" is typically more $$ than a regular test.
Sent from my iPhone using IH8MUD
Off the line it bogs down...like a lot, then all of a sudden its like a turbo is spooling up and then lets loose. It hauls ass! And the S/C isn't installed yet!!!
Not sure why the big bog down off the line but we both think its the throttle body that is doing it. The big bore is affecting it. Not sure whats going to happen when the blower is packing even more air into it.
I will try and record some off the line "runs" and post 'em up. Don't expect any big RPMs cuz I'm not going to push it just it.
*EDIT: now that I think about it, I'm not sure the new Turbo Supra fuel pump was installed yet. That could affect it as well.
grizzlygibbs said:Does anyone suppose that this issue could be due to one of the cables possibly not being tight enough on the throttle body? I know when I took off my throttle body I had to do some tinkering to get it back to where I had it adjusted before, even with having the cables marked. My shift points are still off a bit. I just noticed in the video it seems that your shift points are a lot different then mine, Mine does not get anywhere near 4,500. Might be one of those simple things to play with to see if you get results.
yotakrawler said:So how does it run compared to before? Can't wait to see the supercharger on this thing.
It was 99% the computer had only ten or so miles on it so it didn't adjust to the air/fuel mixture yet. Once the truck hit about mile 20 everything was fine. Not saying the cables are perfect but this issue is now gone.
Cruiserdrew said:So just for future reference, I think the "re-learning" feature of your ECU takes 3 starts, and one of the trips has to be over 55 mph.
So if I've disconnected the battery, I start and idle twice in the driveway, then take it out on the freeway for a mile. Then it seems to settle down and work fine.
landtank said:I think the major problem was the fact that the connectors at the MAF were badly soiled.
Even with a total restart of the ECU it should run without any major issues. But with those bad connections the readings from the MAF were so far off that the ECU needed more time to get things working better and then reported the errors.
NLXTACY said:Well its been only a few days and last night and the night before I need to top off the radiator by adding about 8oz. of water. Called Richard and said he will do a pressure test but most likely its a heater hose, even though every hose is brand new it still may be leaking during pressure. At least that's what we are hoping![]()
Are you getting heat through the HVAC system? Has your thermo opened? Are you over heating?
On a recent engine jobber I did, it took almost 1 hr to burp the system, with the front end raised about 12".
The next day I added almost 1/2 gallon to the radiator, and another day later almost a quart of water. With the rear heater, the cooling system is pretty big.
190 is fine for a 1FZ.
I might have missed this in a previous post, but is your SC new to this rebuild or or already on your engine?
from the throttle body. It's all noticeable. I'm liking it!
