^ dammit, then what did BENO send me ?
Didn't one pic have a Part number sticker on the fan?
rolliges said:Didn't one pic have a Part number sticker on the fan?
16361-65020.
That's the fan I'm running on mine.
The 61020 I have is 17" OD. It sits pretty well centered in the shroud and it has less than 1.5" gap between the fan tip and the shroud. Hard to tell for sure, but it looks bigger than the one in your pic. Mine also back sets over the entire fan clutch, plus about 1/4", so the fan blade is about half in, half out of the shroud. Also, it has two little fins diagonal on the face of each fan blade. Don't know if it really helps move more air, or makes the blades less likely to pull forward at higher rpm, risking contact with the core. Not sure exactly what year/model/market it came from originally. JohnOk good![]()
There was no cutting necessary. Plenty of space all the way around.
I sent you what you asked for.
That fan looks nothing like a tall blonde with big tits![]()
Don't ya already have one of those at home?
OMG!! What's he... she... it holding with their left hand?![]()
So ya take a couple B's ya add a couple G's and you end up with D's.... simple math![]()
Failed smog
• EGR has no vacuum. Most likely a bad modulator but it's only two years old. Hmm
• they couldn't find my OBD2 port. My fault, I turned it for the Scan Gauge2
• timing too far advanced, it needs to be at 3deg for the test. Bastards.
