Electrical
The Ghetto
Ok.....so I think I bought a POS. I am having electrical issues. I have a 72 FJ and it has a brand new battery. When I bought the FJ I had no problems starting it. When I took it home I was testing all the lights just to make sure (maybe I should have done that before I left).
Fortunately they all worked except for the DS turn signal. So, I looked around and realized that it was a disconnected wire. So I tried a couple of wires that didn't have a connection. None of them worked. I then rerouted the rear with the front and it worked.
Then, I went to start the LC and it didn't start. I knew right away that it was the battery and assumed it was because I was testing the lights without the engine running. So, naturally I jumped it and it started. I couldn't get 100 ft without the lights going out and finally the whole vehicle died. Whats up?
Stock Cruiser? First you need a schematic so you are not just plugging in wires willy-nilly. Second unless you were doing this for hours your battery should not have run down that much. Are you sure it's being charged? Get a meter, measure voltage at battery with truck off. Should be in the 12 to 13 volt range. Then start the truck and see if the voltage is now higher like in the 13-14.2 volt range. If all that is good then check for how much current is being drawn from the battery when it's NOT running. Set the meter for current and pull the + battery terminal. Put the meter in series with the cable to see how much current is being pulled. If a lot then put the cable back on the battery and move to the fuse box. Pull one fuse at a time and place the meter (still in current mode) across the fuse terminals. Write down each fuse and the current it pulls. BTW unless you have a radio or a clock or something else you should not read any significant current on ANY fuse unless there is a short on that circuit. I can send you a cleaned up schematic for your truck. Just let me know.
Good Luck!
It sounds like you have a bad connection somewhere in the main power feed between the battery ground and the ignition switch. This is probably unrelated to your turn signal problem.
It is not a good idea to randomly connect wires. Check the color code ot he wire and find out where it is supposed to go by checking the schematic.
I didn't exactly randomly connect wires. I ran the rear with the front after I had issues with starting it. This is frustrating because I am thinking this is going to be costly.
I don't really have input on your short, but....
Doesn't your vehicle only have 2 tail lights on the rear? Each light is parking light, & turn/stop. So.. if you hooked the front turn signal to the rear turn/stop light, won't the front turn signal in question, come on when you hit the brake?
The good news is: this is only costly in terms of time; the wiring itself is cheap. Finding out what is really wrong just takes time. But if you do it systematically, you will eventually be done.
Yes it does have two in the front and rear. The rear have two wires coming from them and the fronts do as well. On the front, one is responsible for turning and the other is responsible for running lights. I tested the rear one at a time and found that the one that wasn't lighting up was the turn signal. So, naturally I hooked the rear inline with the front which they both blinked at the same time. It worked fine.
Honestly, I could just as well use my friggin arm to signal if I knew that the truck didn't die on me. I am currently getting the brake booster replaced and am picking the LC up this afternoon. I am hoping that the truck stays running with the lights off. For some reason, when the truck is running and I have the lights on, the lights go dim and then go completely out, then the whole truck dies. It's a real bad feeling when you're driving on the freeway or so I can imagine. I haven't had the priviledge of that experience yet. So, that is why I am trying to troubleshoot this before it comes to that.
mdjohnsen said:
Snip For some reason, when the truck is running and I have the lights on, the lights go dim and then go completely out, then the whole truck dies. /Snip
Sounds to me like your alternator is not charging the battery which would also explain why your battery is going dead. You may also have a parasitic drain on the system somewhere but I am betting your alt is not doing anything.
You should be able to pull the alternator and take into an AutoZone or Advance and have then test it for you free of charge (no pun intended).
i would take it to a small shop that specializes in electric motors and alternators. I don't always trust the testers in autoparts chain retail stores.
It may only need brushes.
The voltage regulator may also be the culprit.
With the engine running test voltage at the post on the back of the alternator.
Like Claudia said, you need to go through this systematically, checking circuits and components, throwing parts at it will not likely solve the problem on a 30 yr old truck. It is not like dealing with late model cars where replacing an individual parts often fixes the problem. You've also got wiring that previous owners have hacked on, or has just deteriorated.
The 1 wire in the rear for the turn signal is also for the brake light too. Your turn signal switch activates the turn signal and cancels the power from the brake light switch so the light blinks instead of staying on. If I understand the way you have it hooked up, You are suppling power from the turn signals circuit and the brake brake circuit at the same time, when stopped and that turn signal on.
OK.
The rear turn/brake is not the same wire as the front turn because your fronts don't come on when you step on the brake.
Get a schematic and study it. When you look at the color codes you will know what wire goes where.
Fix the starting issue first as that is the most frustrating. If there is a significant current drain when everything is off then find where this problem is as described above and fix it. If there is no current drain then maybe there is a bad connection. Start with the battery ground, battery cable connections, connection for the big white wire that goes to the amp meter in the dash, wire from the meter to the ignition switch, etc and clean and tighten these connections.
It's not fun, but it is easy if you have the schematic figured out.
mdjohnsen said:
Cruiserparts.net has brand new OEM alternators for $89. That sounds pretty good. How can I test my alternator to see if I actually needs to be replaced?
Or listen to Coolerman. Check the voltage of the alternator with the car idling and it should read around 13-14 volts.
Mark
Power Distribution
Well lets do this sytematically then. You stated that the truck would die if driven 100 ft and the lights go out. Those two circuits have a couple of things in common.
Check the following connections:
Battery cables: Pull the + cable off and CLEAN it and the battery post. Leave the + cable OFF for now. Now do the - cable but go ahead and reconnect it to the battery.
Next check the grounding. The - battery cable should go to a junction terminal on the frame with a jumper to the engine. Pull all of these and CLEAN them. Chase the threads in the frame and the block with a tap. Chase the threads on the bolts with a die. Use a copper based anti-seize on the threads and reconnect the grounds. Tighten them all back up.
The + Battery cable will go to a large terminal on the back of the starter solenoid. Pull the + cable off and CLEAN it and the white 10 ga wire ends. Then clean the terminal and the nut. Apply copper based anti-seize and tighten back up. The white wire goes to the AMP gauge. Make SURE the + battery terminal is NOT connected then remove the instrument cluster. Find the AMP meter terminals. Remove the nut holding the white wire on and clean the terminal, nut and wire end. Replace and tighten it back down. Remove nut holding the white/blue wire. Clean the terminal,nut and wire end. Replace and tighten. (This wire goes to the alternator and fuse block.)
Fuse Block: Get a dremel tool with a small wire wheel. Remove the fuse block from the firewall. Remove each fuse and use the dremel to clean EACH fuse end and EACH fuse panel fuse retaining clip. Use a pair of needle nose to bend each clip inward a bit so that is grips the fuse tighter. Now one at a time remove each wire going to the fuse panel and clean the wire end and the conection point and the screw. Apply just a touch of anti-seize to the screw threads and reattach the wire. Wipe off any excess antiseize. Replace the fuse panel on the firewall.
Alternator/Regulator: Remove one wire/plug at a time from the alternator. Clean the terminal and wire end. Use a dremel tool with a small wire pencil brush to clean the plug in terminals. Check that the alternator is grounded. Pull the bolt holding it on and clean all surfaces that would ground it. Replace and retighten. Repeat this for the regulator. You might even pull the regulator, take it apart and use the FSM to adjust it and clean the contact points.
Reconnect the + battery cable and try to start and drive it. If it fails again then pull the + battery terminal, remove the key switch, disassemble it and clean all the contacts and wire ends. Reassemble and try it again. After doing all that report back what you find.
I realize that doing all that is going to take a couple of hours or more depending on your knowledge but it is the only way to ensure you have a reliable power distribution system.
Wow, I appreciate everyone's feedback and help. Now, I was going over in my head what have I done and what is involved here. When I took it into the shop I had to have it towed because it was early morning where I had to use my lights and then everything died. I called the shop and they said they had to jump it to start it but throughout the day they started it just fine. Interesting. I can also remember when I was testing the lights because when I turned the key once to utilize the turn signal the aftermarket voltage dash gauge read as 12-14 Volts. So, when I turn on my lights something seriously drains my battery. When I get it back this evening I will take a picture of my dash because it was totally redone sometime back by either the seller or a retard before that. The dash has aftermarket AutoZone or PepBoys type get anywhere dash gauges. The steering column is a Chevy steering column. So, basically I am dealing with almost nothing as stock which OEM schematics would be useless.
I am going to disconnect the headlights first to see if that is the drain culprit. If not that then I will try all other lights involved when I pull the lights swicth. Obviously it's not an alternator issue b/c if it was the truck wouldn't start during the day without the need for lights. I also noticed that there was some condensation behind the driver's side headlamp so maybe something is grounding and draining when I give juice to the headlights. It could be a number of things but I will try this first.
Ah now the real culprit shows itself! That nasty entity the PO! (Previous Owner for the new guys) At this point you might still try pulling the fuses one by one to see which one is pulling the current. That's assuming the PO fused things properly...
It sounds like you have quite the basket case on your hands due to the proverbial "previous owner" PO.
HA! Coolerman beat me to it!
Go here and follow these instructions to see if you have a parasitic drain. http://www.autoshop101.com/trainmodules/batservice/118.html Then if you do, start pulling fuses one by one as Coolerman states above to try and isolate which circuit it is.
PS. I am still working on getting you hardtop pictures. Where in VA are you? Our local LC club has our next meeting the first Wed of the month and if you can get this thing running and bring it out we may be able to give you some insight on what you are up against with this truck. We meet in Arlington at Jack Taylor Toyota.
Clean connections and reseat connectors has been mentioned several times above. copper oxidizes and regardless if it's oem or a PO'S basket case they need to be cleaned and verified they are making a good connection. You also may want to add a ground cable from the starter to the Chassis/frame. This upgrade is not in your cruiser unless the PO has already done it, howver Toyota did it later on some of their newer models.
Get a multimeter and check the voltage on the battery prior to starting and after and see if there is a difference. Rev up the engine and the voltage should stay pretty close if not check the voltage regulator could be going bad or is bad. If the alternator isa 1972 OEM set up, the voltage reg. should be external and located on the firewall. If you do replace this item, aftermarket ones may not work as good as oem. The Napa place at near where I grew up can actually check the Votage regualator by it self. Also some autopart stores have a standalone system that can check the whole system in the parking lot. Since this is new to you I would make sure the battery is actually a good battery. You can have the battery load tested to make sure. Have lots of patience. Good Luck.:)
