Also Coolerman mentioned to check if the electrical system is drawing current when the ignition switch is in the OFF position. It should not draw any current unless you have a radio with a clock on it. But even then, this should not be enough to turn on the test light you will be using. Disconnecting the + positive lead on the battery terminal and reconnecting the test light in series will complete the circuit so if the electrical sys. is drawing current the light will turn on. If the light turns on diconnect what is causing the problem. One of the first places I would disconnect is the voltage reguator.
