EFI Relay Bypass Kit (Immobilizer Fix) for UZJ100/LX470
PM'd you for two kits! Please LMK if you have in stock and best means for payment. TIA
Hi Medtro
Because I am a new user, I am having issues with the PM. I would also like to purchase one of your EFI Bypass kits. I have a 2002 Lexus LX470. It is suffering the issue you described. I sent an email to your gmail address on the initial post. Or you can probably PM me. But for the last 20mins the system keeps saying oops there was a problem when I attempt to message you.
Thanks
Chris
The system actually posted the message even though it errored on my side. Sorry for the spam. But definitely not done on purpose.
Hi Medtro
Thanks
Chris
Email replied.
Hi Medtro. I would like to purchase a kit as well, please let me know how to do so. My lx is sitting at bell Lexus as I type this for the same issue. Thank you
@medtro I'd like to purchase one of your kits for my 2000 LX.
Thanks for all of the information you've put in both this thread and the "My immobilizer fix" thread. It has helped me become "unstranded" more than once. But now simply changing the 20 amp fuse isn't working. So its time for the kit.
I've sent a PM and email.
PM and email replied.
PM replied.
This bypass kit bypasses the bad EFI relay circuit in the fuse box so that the immobilizer system gets adequate power supply for starting the car. I made this for myself after my new 30A replacement fuse - initial fix for crank but not start problem, failed to start after 4 days. Some members have showed interest in the kit and asked me to sell this kit.
This bypass kit is for you if:
  • You are told a new fuse box 82720-60023 will fix your intermittent starting problem but you don't want to spend $700 just for the part alone
  • You have intermittent starting problem and you replaced the 20A EFI fuse with 30A fuse or paper clip
  • You have intermittent starting problem and you have been tapping or removing/replacing relays and fuses in the fuse box
  • You want to have this kit in your glove compartment in case you run into this crank and non starting problem
The kit is designed to connect to EFI fuse slot. It is 100% plug and play provided there is no damage to the EFI fuse slot. If your EFI fuse slot is melted or damaged, you will need to connect the kit to the battery.
Kit comes with relay, 20 AMP fuse and installation instructions. Fuse holder may not be the same as shown in picture. $140 shipped to 48 states. Please contact me for payment info or shipping cost outside 48 states.
pm sent
