Early F engine spark plug question
Seattle, WA
Hey all. Trying to figure out the correct 3/8” reach plugs to get for my 1964 F135 engine. What is the correct Denso or ngk plug to run? I searched but only found the Denso w16p-u plug mentioned but what was discontinued.
Someone like @Splangy or @Poser might know if the plugs listed below are ok in an old 135F.
Spark plugs: NipponDenso W14EXR-U for mixed street & trail, W16 if running on highway mostly. EX-U can be used if radio interference is unimportant. NGK BPR4EY is a good substitute for W14EXR-U, BPR5EY for W16EXR-U.
Be sure to get a plug hot enough for Cruiser. Denso W14EXR-U is a good one.
Thanks all! In my quest to tune up this old F motor I discovered the timing is off by 180 degrees. So another challenge has presented it self. It runs but I need to fix this soon. Not sure what happened in its previous life. Guessing someone installed the dizzy out of the correct rotation.
So I see W14 and W16. What’s the difference if both work?
Looks like heat range. @treerootCO mentioned the w17 was the OE plug for the F135. So going by that the w16 might be the closest heat range wise. But it honestly might be splitting hairs.
Hopefully an expert will weight in.
I don’t think it would run if you were 180 degrees off. Well, not unless somebody installed the wires on the cap 180 degrees off to compensate. I’ve never had one run 180 off.
Yes the wires are also flipped 180. Only way it will run. So the 1 spark plug starts at terminal 3 and then goes in the correct firing order from there.
