is this the correct filler tube i will need ?
so where the vent tube is connected ? to the carb base ?The first on that you posted is the one that is correct for the F135
Yup!so where the vent tube is connected ? to the carb base ?
do you have a full picture of this setup ?Yup!
The Toyota parts diagrams stop at 69 but in fact they show setups pre-69 sometimes. The routing on the top diagram is actually correct! Just imagine the carb base being a single port carb base and not twodo you have a full picture of this setup ?
because this setup seems to be for a post 69,
Yeah I can get one later no problem. The OG one is made of some phenolic fiber material that can crack over time. I believe Mark @65swb45 sells a machined aluminum one. Maybe he can tell us if it has the PCV port built into it? I cant remember.thank you dudes !
is there a view of the carb base ? don't have it
i have the old style oil bath air cleaner... and the engine i found to install have thoses slits on the valve cover, so what will be the good setup finally ?Actually not all F135 had that one. With slits on the valve the other one would have been correct. With actual PCV valve you will be moving more volume out the crankcase. The downside is the make up air thru the valve cover is not sized or filter the air the style with tube running to the air cleaner. At one time had a few cruisers with the draft tube style on the oil fill neck. Those are all sold. Have some early oil bath air cleaners but never paid attention of they all had the tube for the hose going to the valve cover.
www.cruiserworks.pt
photos.app.goo.gl
here is the Album with the last pictures of the body transformation from 1969 to 1964 ....i am not a bodybuilder, i learn all by myself
thank you to Cruiser works portugal for the perfect rear fender body panels !, they are gold !
Cruiser WorksPT
CruiserWorksPT Peças e Restauro de Toyota Land Cruiser BJ40. Todo tipo de restauro para carroçarias Toyota Land Cruiser BJ40.www.cruiserworks.pt
Fj40 - 1963 - CAISSE - RENOVATION · Mar 23, 2011 – Sep 6, 2026 📸
Shared album · Tap to view!photos.app.goo.gl
