Build dunkane 1964 fj40 restore thread
had two tranny covers to make one .... nice
cant answer on the rear barn doors... I always thought they were the same bolt pattern for all 40's... I assume there isn't play on the door female end.... where one can come down and other up?
I tried. For sure...will move the holes....not a big deal
here is my favorite group when welding, hertz is one of my favorite with Jerkin
Finally...with somes biggers holes on the hinges...it is perfect.
Rear door locker dissasembly...was rusty like a wrecked ship
Much better
Your opinion on this 68 tub under body
modification....cross member cutted ,why ? Because of 4 speed conversion ?
hello i have the same tool box under driver seat, but seems there is no hook on the cover for the 2 latches
why ?
On my 72 the latches clip on the seat frame. Unhook the latches, slide the seat towards the door, remove the seat, open tool box.
ohhh ok , thank you :) dudes !!!
Today have 2 hours to check pedals...but gas pedal seems knock on the hump ,like i am usinh a 68 tub with somes 64 parts (somes are.missing). I don’t know wich pedals i am using right now
If you have somes indications...i am in.
This is the 64 gas pedal linkage i believe ..but don’t fit on the 68 tub...
That looks like a 68 to 72 pedal assembly.
What part is it ? (So many parts i don’t know )
Question : my fj40 body is a 68 modified to match 64 ..i have a F155 engine and a 4 speed gearbox ...wich parking cable have i to use and wich accelerator cable setup ?
