Drawbacks to using drop brackets?
OK, hate to bring up an old topic, but I'm now looking at lift options ;)
As some of you already know, I'm currently running factory original front coils with MT 2" spacers and a set of medium 860's out back.
OEM LX shocks all around
Since my rig is super heavy (BIOR front bumper, dual swing outs, dual batts, front and rear winches, full rack, s*** ton of recovery gear, etc., etc.), I'm still around factory height :meh:
I'm thinking about stepping up to a 3" heavy lift, but don't want to deal with bushings at all (especially since the factory bushings still look great with about ~half a million miles on them), so it will either be plates or brackets :hmm:
I don't wheel my rig nearly as hard as some of you guys, but I do enjoy taking her out to the trail every now and then.
That being said, road manners are very important as I do quite a bit of long distance driving :steer:
Thing is, the MAF brackets have been out of stock for quite some time now and it seems plates are the new in thing :confused:
Are there any other choices at this time?
Should be good to go with Caster plates with a 3" lift. As for road manners, my current Slinky 3" HD kit has had by far the best road manners and ride of any of the different setups I've had in the past 20 years of owning/driving an 80 series.
I'll bet they aren't in as good a shape as you think they are. Age kills rubber. Start flexing those and they'll likely come apart.
I use plates with about 2” of lift. More caster than spec is good in my opinion. Axles I’ve built in the past I’ve put 7 deg for drivability.
Remember that with caster the pre-8/92 factory caster setting is under + 2 degrees while with the 8/92 up it's +3 degrees. So any mod to lift, etc needs a full wheel alignment report to check if caster is in spec (more than +1 and less than +6 would be the extremes IMHO).
Since this thread was created I now offer caster plates for lower lifted trucks. I would highly recommend that everyone install the springs on the truck and then take a measurement from the hub center to the underside of the flare to determine the ride height of your truck. This should be done after a short drive to settle everything in. It's the ending ride height that will determine how much correction you need not necessarily the springs you use.
