kbahus: I decided that I am going to go ahead and do the front diff breather extension. This will eliminate the front diff breather clog as a cause. Once I do this do you think I will have to change the inner axle seals or just clean things up, regrease, and change the diff fluid?
Also were you running marlin inner axle seals when this happened to you?
I would prefer not to change out the inner axle seals because I really want to love the Marlin seals...
Did anyone else who extended and or cleaned their breather hoses experience leakage from the marlins after the cleaning/ extending? Thanks for all your help, now I know this baby is going to get fixed right and be one step closer to safe deep water crossings.![]()
98 SNAKE EATER: Yes I did. I am hoping the Marlin Crawler seals arent crap and its just the breather hose like kbahus said,"Check your diff breather and make sure it's not plugged. If it's plugged it will cause a vacuum and suck grease past the seals into the diff. Happened to me."
But now that I think about it more I think my problem is the diff fluid flowing into the knuckle, however I could be wrong. The reason I am thinking this is because there is diff fluid that looks to be mixed with grease pouring out of my drivers side front wheel. But I could have both ways cross contamination, but I am fairly sure that I don't just have grease into the differential (i have not drained it yet so I am not sure...)
Please help me with your big brains mudders![]()
The marlin seals don't even use a spring, they instead have a wire ring with A slit cut in it.
