- Thread starter
- #81
All that random crap you always wanted to see...
Wait, did I post this? Did you look at page 4?
Why can't you fit air to air like Dustin set up?
Frozen boost intercooler cores are pretty poor quality. I had the 600hp one and was not happy with it's performance. It's definitely the IC underperforming and not the heat exchanger, etc as the fluid never heat soaks. If I knew then what I know now I would just have ordered the Bell core and had end tanks made. Bell will custom build an intercooler to your drawing.
Love the stance of your truck. How does she run down the road?
Great work.
What did you end up doing with the steering shaft?
Any videos?
Take a look at the Donaldson IC that cimarron has in his truck. It sits up above his winch. If you are running an auxiliary PS cooler other than the paperclip in front, then you may need to find it a new home.
Yeah... I think the air to air would just be easier. I'm not sure how much effort I want to go through at this point in putting in an intercooler. Almost think it'd be easier just to stuff in a water/meth setup and be done with it.
And I really would like to know how much this intercooler is lowering IATs so I could decide if it's worth keeping or not.
IC is actually a Mishimoto. My air filter housing is a Donaldson.Thanks man. I'd love to run air to air if I could fit it.
It's just the stock trans cooler, re-purposed since I'm running a manual trans. IDK maybe I can make it fit. Not sure about tubing though and fitting between my batteries. Could be tight.
I'll definitely look into it though. I hit 1400 in a hurry the other day; and just going down the highway, if I lay into it I can hit 1300 pretty dang quick. It's fueling hard though and the Lucas 300 PODs don't help either, they're smokey as hell. Even at full boost on the highway at 80 mph it wasn't clearing up. Would definitely spend the extra 200$ on some proper injectors if I could re-do. They make some power, and they lay down some smoke if that's what you're after but between them and a denny T stage 2 pin, I had to dial my AFC way back and it still smokes like a SOB if I get on it. So that's definitely part of my high EGTs.
I think if I could get a proper intercooler and an HX35 I could fuel hard, not smoke as much, make more power and be happier.
It's just a matter of funding and at this point this thing has been sucking me dry.
