For Sale Colorado: 1976/Toyota Land Cruiser/ FJ55
Status
Not open for further replies.
Colorado
Year
1976
  1. 55 Series
Westcliffe, Colorado 81252 United States
Mileage
71663
Color
Green
This FJ55 has some updates, along with a lot of stock items remaining. A 2” OME lift kit was installed, and most of the smog/old carburetor were pulled. Those parts are still in hand and will go with the vehicle (listed below). An old Warn winch was also removed, and will be included. I am the third owner of this vehicle. This has been garaged, and a semi-daily driver.
Price: 33k
There’s also a list of spare parts included in the purchase. These parts will not be sold separately:
NEW PARTS
-Windshield
-OEM Outlet Gasket X2 (thermostat housing)
-Top Thermostat Gasket
-Weather Strip front left door
-OEM Door Window Regulator X3
-Weather Strip front right door
-Switch Assy (tailgate window)
-Fuel Pump Gasket
-Distributor (internal) X2
-Condenser Dist X2
-Shims
-Valve X3
-Oil Fill Cap
-Hardware (bolts)
-Right and Left Side Mirrors
-Windshield Seal
-Distributor Cap with Plug Lines (and another Cap without lines)
-Thermostat Housing Bolts X3
-Clutch Master Cylinder Kit X2
-Alternator Belt
-AC Belt (not equipped)
-Wiper Blade
-Starter Solenoid
-Break Cylinder X2
-OEM Spark Plugs X4
-Distributor Rotor X2
-Fuel Filter X2
-Approximately 3Ft of Fuel Line
USED PARTS
-OEM Front Seatbelt
-OEM Tailgate Window Motor
-Radiator Hoses
-Thermostats X2
-OEM Air Cleaner
-OEM Brake Master Cylinder
-OEM Carburator
-OEM Front Right Door Hinge
-OEM Various Smog Parts
-OEM Fuel Pump
-OEM Upper Thermostat Housing
Wow, that's a beauty! Very good price.
You might want to add this into the new Classifieds section here on MUD because it's not showing up under FJ55's for sale in that system. At least, I didn't see it. Only one was in the FJ55 category and it was Nolen's blue pig that has sold.
Status
