Thanks, started breaking down the front axle, I'll get it removed tomorrow and start the cleaning process, and prep the springs for new bushings. Time to order a new Terrain Tamer knuckle kit for the Disc brake conversion. @orangefj45That steering gear box went from crusty to pretty! Nice work.
Ron will advise you should only run Budweiser in there.What do ya use in Ultrasonic cleaner??
I will be curious to see what is in the kit!Thanks, started breaking down the front axle, I'll get it removed tomorrow and start the cleaning process, and prep the springs for new bushings. Time to order a new Terrain Tamer knuckle kit for the Disc brake conversion. @orangefj45
Pretty much comes with everything you need, They even upgrade to the Marlin duel inner axle seals, Spent a few hours getting the 54 years of dirt and oil sludge cleaned off the front axle. Over the next few days I will finish cleaning and prep for paint. So much cleaning LOL we want to do it rightI will be curious to see what is in the kit!
Bud cleans out everything.Ron will advise you should only run Budweiser in there.
Where did this Pig come from?Got around to getting a few things done. The massive piece of angle iron welded to the frame was a PITA. It was the support bracket for the snow plow. I did some scraping and a little with the wire wheel underneath. That got old quick so Wendy helped me get the 55 set up to rent a serious power washer tomorrow. Right now I a just working to get everything clean and replace any gaskets and seals I can get to without pulling the motor and trans.
I love the name Snowplow!Snowplow ( The new name of the 55 ) is all cleaned up and back next to the shop. Gaskets and parts are showing up and the weather is getting better. The Mini truck disc brake stuff I had stored has some issues so I am going to use the axle I was saving for the Troopy. Its been stored a while so I and going to break it down make sure is in good shape.
I know all about the "Hey, while I'm in here" phenomenon...New 3:73 third installed and the front axle is on hold for now, I picked up the remaining gaskets I am going to need so first off was pulling the oil pan. Nothing like trying to clean 54 year old gaskets LOL It might seem like I am all over the place I have a plan. Its so much easier getting to everything with the front axle out.
Always fun to have some quality help!Had some Great help this morning getting the new gasket and oil pan installed. Taking the rest of the day off.
