Bought another steering box and 60 -series steering shaft last week, the box I have is in serious need of a rebuild, factoring in shipping and the cost of rebuild, I opted to buy another used (non-leaking...yet) gear box. I'm going to try and use all Toyota parts (splined and u-joint) instead of the McMaster-Carr u-joint and machined woodruff keyed shaft. Similar to what I did on my 45 LPB, I used an FJ55 steering shaft/firewall set-up on it and it's worked well.
Started reading up on 24V stuff...lots of info and opinions to sort out. This engine was in a 24V vehicle. It's now in a 12V vehicle. I
thought I could use the 24V starter, alt. etc. and run my 12V accesories via a relay and converter, but the more I read the more I'm thinking I should source a 12V alternator, starter, glow plugs and ditch all the 24V stuff altogether. Is this the consensus for these types of swap?
The reason I was going to keep the 24V stuff is because I have it, but if keeping it means I'll have issues with batteries (which aren't cheap), than I'd be ahead if I sourced 12V stuff right now.
Opinions? 24V starting, 12V everything else?
Dan
FAQ is your friend,
https://forum.ih8mud.com/threads/24v-engine-in-a-12v-truck.30469/
doesn't look like a good consensus though...
