- Joined
- Sep 28, 2002
- Threads
- 558
- Messages
- 8,123
- Location
- Kamloops, BC Canada
- Website
- www.shopraddcruisers.ca
Oh man, that is so great, beautiful child.
I have two myself.
I have two myself.
Well not much done lately, put new battery cables on. The old ones came apart in my hand when I took them off. Had all the fluids changed and brought it over to inkpots to see about welding up some brackets for my front seats. Still have to figure that one out.
I wanted to take the front turn signals off and sand them down and paint them but ended up destroying one of them... 35 year old plastic is a little brittle, add a rusted out bolt and you got hour plus messMy passenger brake light isn't working now. I'm hoping it's because the turn signal is gone in the front? I replaced the brake switch (broken in 2) but it didn't seem to help. I have a new set of the 75+ FJ40, 55 turn signals but need the correct foot for them. Anybody know who sells them or the correct front turn signals?
On a good note my daughter was born on Friday morning and we finally get to go home tomorrow.
Here's a pic. of Camille 9lbs 11 oz
I installed the NOS Toyota Brake MC and new shoes all around, bled the system and adjusted the brake pedal rod. Everything works great for a little while and then the pedal gets hard as a rock and locks up the brakes. I adjusted the rod as far back as you can go and still had problems. The shop looked over everything, bled the whole system again, re-adjusted the rods and they are having the same issue... WTF!? What are we missing? It has not been a good week on the pig front.
luke i dont think your crazy,, after i move the rear wheelwells i will bedliner the whole inside floor and up the sides about 6".
chet if the engine is running smoothly you should be ok on damage, just pay attn for a while to any ticking or knocking that may develop.
like brett said, and since you replaced the MC, i'd check the rod from the booster to the MC, it is adjustable and needs to be right. unfortunately you have to take the mc off again to check it.
Well found out they didn't have the distributor in correctly and it wasnt pumping oil to the motor. They spun the oil pump by hand to get oil flowing and re-installed the dist. I guess it runs fine now. Now what do I look for as far as engine damage? How would you know if something got screwed up other than weird noises and poor performance? This shop was recommended by other LC club people here in AZ and they "seem" to know what they are doing.....
Chet
Rhino - I don't suppose you have a portable welding/steel fab operation in that Massive pig of yours![]()
Check oil pressure...
adding grease to any part of a brake setup would of never crossed my mind.
