Chet's 1974 FJ55 Build
Maricopa, Arizona
Hello, I've been lurking around here for a little while and thought I start a thread where I can show how not to do stuff ;) I bought this from azredliner down in Yuma, AZ. It started right up with a little gas down the carb but would die after the gas ran out. I guess it had been sitting for a couple of years if not longer. The rear window regulator was gone (to my surprise) so at least 2 years of dirt and rain had accumulated in the back and all over the green shag that was mounted thru-out the pig. It was dirty and nasty inside. Looks like somebody had grease or oil in the back and the underside is just covered in a thick shell of mud.
The tires are all dry rotted and hold a little air. It looks like the motor has been totally de-smogged. It has a 1.5 F motor and original carb. After buying all the parts needed for a full tune-up I found out the PO had a '69 Chevy distributor on it. It seems to work ok, still haven't timed it yet. I had it running pretty good, but it was hard to start after it sat overnight. I drove it around the block and I could get up to about 30 mph before it started puttering and backfiring like crazy. It had a nasty exhaust leak at the manifold until I replaced the doughnut gasket. I siphoned as much of the old gas out as I could and it smelled like turpentine. I put in about 5 gallons of supreme gas and some octane booster and it seemed to help a little. But the same thing kept happening. I finally decided to have the carb rebuilt (marksoffroad) and take the fuel tank out and have it boiled. Well turns out I have a Long Range tank setup and it was a bitch to get out. It is held on by 4 long threaded bolts that go thru the rear cargo sheetmetal and had a large washer and a couple of nuts holding it on. I'm guessing a 45-50 gal tank. After busting 2 of the bolts off, I soaked them in PB and let it sit a few days. I finally got it off but one of the bolts had rusted to the tank and I think it started a pinhead leak. I poured out about 12 gallons of newcastle beer colored gas, full of rust and gunk. The radiator shop said they will have it done tomorrow so hopefully it's alright.
I gutted out the inside, not a lot worth saving unfortunately. The headliner was in ok condition but stained and ripped in places. The seats are nasty and had already been re-upholstered. It looks like somebody started restoring the pig but just put carpet over the rusty areas in the floorboard. And painted over the original green and white. The drip rails are pretty mangled in spots. The PO (not azredliner) had a roof rack that bent the rails really bad in a couple of places. The dash is rough but workable. I wish the 55's dash looked like the 45 or 40's. I really want to get it back to somewhat stock. I have to have AC here in AZ so that's a necessity. I love the Pumpkin Pig in the 55 registry and want to go for that look. I just want to be able to go out and :steer: it! Thanks for reading my ADD little story.
Chet
In Yuma all strapped down. There is a little dent in the passenger door, otherwise the body is in decent shape.
Inside with rear seat taken out
I though the dash wasn't so bad...
Until..
One of my car models ;)
My other one doesn't like Dads new smelly truck.
Great looking Pig.
I'm sure your kids will love it once they go for a few rides.
Keep posting your progress.
:cheers:
I love it. Lots of small issues but the body looks great. That's the biggest step on these vehicles.
I'm almost tempted to get on a plane and fly out there and replace your fuel lines. They make me want to cry.
A grinder with a flapper pad on it will smooth down the cracks in the dash pad so the liner will lay flat. Might have to use a heat gun and some weights to get it to lay flat. Then glue the heck out of it.
I'm not sure if I'd have that Chevy distributor in there. I was under the impression the gears were a little off and it could eat your cam. I'd find a replacement fast. Your rubber fuel lines are shot. Replace with 5/16 hose and new clamps. The metal ones need to be cleaned. Cap the lowest end of the line back at the tank with the old rubber lines installed and slowly pour mineral spirits in it from the inlet connection at the fuel pump. Don't put it in the fuel pump. Let it sit for a couple day and then blow it out. I'd probably run some brake cleaner through the fuel pump. Get it clean. Or you will just have problems all over again. When Mark rebuilds the carb see if he has the float bowl valve that has the little screen filter on top. These are good for filtering the fuel before it gets into the carb. A lot of rebuild kits don't have them.
Get som 5/8 heater hose. I prefer Napa. Don't get the crap from Auto Zone or Advanced. Get a quality hose. Cause it's going to be under your ass. Replace all the heater hoses. And don't skimp out on hose clamps. Pull the radiator hoses and inspect. If they feel brital replace. Look into the water pump while you have the hoses off. Does the inside look pitted. If so spray some PB blaster on the bolts for a couple days and then remove and replace.
Replace the oil and filter before you drive it any more or start it. Bad oil that has been sitting for a while is not good and can plug passages. If it has been sitting for more than a couple years I'd pull the pan and clean the oil pump screen. I'd also run a couple of can of engine cleaner through it to get the crap out. They sell it at most storre in an old looking oil can.
Replace all fuids. Even if the radiator fluid looks good, flush and replace. Tranny, t-case, diffs, brakes and clutch.
Do all this and you should be good. Don't, then expect to have issues.
Oh and while the gas tank is out have them line it. It's cheap and good insurance. Cause you cannot just go and buy another tank easily. 55 tanks big or small are not easy to come by.
Looking forward to the build. Your way ahead of me already.
Thanks for the comments, and tips. Please keep them coming. I'm not trying to make it sound horrible just what it is. I think it's in pretty good shape considering some I've seen. The inside is bad, the outside is pretty good. I already changed out the fan belt, radiator hoses, fuel pump, thermostat, and flushed the radiator. I need to do the oil, Tranny, t-case, diffs, brakes and clutch still. I poured in a can of Seafoam right when I got it so hopefully thats doing something. I have new brake shoes and brake hoses ready but have never messed with drums before so I'm a little nervous. The brake pedal needs to be pumped to keep pressure. I don't see any leaking from the Brake MC and the reservoir's are still full. Bad brake booster? Air in the lines? The heater was disconnected when I got it. The rear heater fan was shot. I pulled it all out and plan on getting a aftermarket AC/Heater. That's one thing that needs to work or it will never get driven for 9 months ;) I plan on using the pig for my DD and light wheeling. I found that getting the right radiator hoses was a pain. The top hose is to long and I'm screwed on the bottom because the heater "T" fitting was gone when I got it. They had rigged a napa hose to fit but it's the wrong size. Any ideas? It's a basic L shapped hose with a 1.5" opening on top and 1.25" on bottom. I thought about trying to find the fitting and just capping the heater hose side. I'll try to take some better pictures tonight.
MC doesnt have to leak to sink,,, if the piston seal are bad fluid can move back and forth past it.
rad hoses are available from one of the many cruiser parts guys on this site. check around for who has them at any given time, kurt, cdan, ect.
the T fitting is something you can get aftermarket, ask the napa guy to look in the catalog, but i bet one of the guys here has a good used one.
drums are not so bad, do one at a time so you can look at the other one for reference or take a pick before teardown.
i have a dizzy.
Thanks PabloCruise and Lucy_FJ55! Getting her driveable is priority #1 right now. Then AC, interior, outside body & paint. I'd like to do a frame off some day but that's down the line a while.
I have a question for all you motor guru's, what dizzy's will and won't work with my setup?
I have a 74 1.5 F motor, de-smogged. The carb is being ported for vac advance. Would this one work?
TOYOTA VACUUM ADVANCE IGNITION DISTRIBUTOR
Thanks again!
Some more misc. pics :)
Do you guys think replacing both the Brake and Clutch MC is a good idea? Cost isn't really bad and I'd rather do it now when it's just sitting anyway?
I've got a lot of oil seepage along the back valve cover. I read that the steel ones are prone to leaking? Worth getting an aluminum? Also the two sensors need to be rewired and possibly replaced. One is the water temp (the t) and the other is?
Look at the rust already on the brand new water pump :( I would of painted it or clear coated it.. had I know.
This is what the floor looks like under the black crap on the drivers side, not bad. The whole inside is colored/covered in rust/poo colored glue used to hold the shag down. Nasty stuff..
Could use a nice steering wheel..
Are these the original bumpers? (the plastic bag is to cover the rear window until I get a regulator from Mark)
Anybody have this plastic piece? Front passenger door.
Reverse light lens? Or newer replacement options for all of the running lights, turn signals, brake lights?
I've seen a ton of the newer 75 up versions, but no 74 and older.
Anybody tried painting or powder coating the dash? It's the one part of the 55's I just don't care for. The ones in good condition are cool but mine isn't. How hard would it be to use the FJ40 steel dash and gauges? I know thats messing with the whole stock look but you can only polish a turd so much..
I got my gas tank back and they cleaned it up nice fixed some leaks and even painted it. Not to shabby.
very nice pig.....you got a very good one by what I can tell..............the dash will clean up nicely; look at Brett's thread on cleaning up knobs + heater and Trollhole's on dash restore; lots to do to get them reliable and rustfree/protected without chasing down a lot of tangent variables
IMHO; if its working don't fix it...........just my 0.02:cheers:
Lou
